330kw Thanks To C&v
BFHOON
  • Member For: 21y 5m 7d
the surge tank cv fitted today has the option of fitting a second pump just by removing a bung, this will be added when my atomic donk gets fitted.
I
BFHOON,
Can you tell us what surge tank C&V fitted?
Benny
  • Replies 20
  • Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car
  • Member For: 21y 6m 21d
Its a custom 3.2 litre surge which can run either single or twin 044 pumps
CYA JEFF :roflmbo:
  • Member For: 17y 6m 14d
the drive home was awsome 1/4 tank of fuel and hammering around corners is somthing new.
How can you hammer it around corners with that power??
What suspension set-up are you running?
My torque comes on so hard if I hammer mine around corners it loses the back end very quickly...
I'm running front and rear sway bars....will my king springs and koni shocks going in soon make it grip better?
Edited by gilto
  • Member For: 18y 9m 19d
thanks guys.
I took it for a long drive up the bells line of road to lithgow and back, all I can say is wow the extra 50 rwkw is deffinatly noticable.
I also have a tune with 280rwkw on 9 psi.
  • Member For: 17y 11m 29d
Good power curve mate! Just be careful when powering out of corners. Its a fine line between no boost and then back end coming in front of your front wheels.
Cheers Alf.
  • 1 month later...
  • Member For: 16y 8m 11d
well I have been adding bits and pieces to my car after getting my plazmaman 800 kit fitted and finally got a retune done.
330rwkw of tyre smoking fun. im looking forward to getting to the creek to see what times I will get now.
so I guess this makes me a member of the 300 club, soon to be 400 club.
mods are capa xcal2 plaz 800 kit dekas surge tank with 044 pump and a 5 inch cat on the stock system.
How much boost are you running for this tune? And have you done any mods to the turbo?
its around 15 psi, no turbo mods at all.
mine seems to hold 15 tapering down to 14.7 on the rev, stock actuator and wastegate.
im using a high flow cat on the stock rear pipes with the centre muffler removed. it has enough flow to make boost but not too much flow as to create boost creep.
  • 6 months later...
so now I have added wastegate and actuator mods and some exhaust mods, with more boost power has upped a bit since then.
the next step now is a motor rebuild, this has been postponed due to the pending bitrh of my first child.
