ETM Member 1,194 Member For: 18y 2m 17d Gender: Male Location: syd south Posted 08/06/08 04:06 AM Share Posted 08/06/08 04:06 AM F6BF said: Our fords are too heavy for a glide......better sticking with a 3 speedpowerglides sit behind some very very powerful and heavy cars in the states Link to comment https://www.fordxr6turbo.com/forum/topic/46437-c4-or-turbo-400/page/2/#findComment-689869 Share on other sites More sharing options...
bluprinturbo Donating Members 605 Member For: 17y 19d Gender: Male Location: brisbane Posted 08/06/08 10:35 AM Author Share Posted 08/06/08 10:35 AM Fatsex said: Why wouldn't you run a C10 over a older and weaker C4?your probably just taking the piss but just in case you arent,c4 c9 and c10 are basically the same box.the c6 is the one that's different and from what ive been told the strongest.ive got a c4 lined up for nix so I may as well get it built.I have heard also that the t400 is a better box and would go down that path if that's true.another box that crosses my mind is the t700.they can be built to hold good power and have overdrive but im not sure if they'd like the weight of our cars.I know theres built 4spds out there coping well but in probably every 10-11 sec car they have failed. multiple times in some cases.I want a tough as nails box that doesnt mind 850-1000nm at 2500rpm.ill have a talk to bob grant next week. Link to comment https://www.fordxr6turbo.com/forum/topic/46437-c4-or-turbo-400/page/2/#findComment-690075 Share on other sites More sharing options...
bluprinturbo Donating Members 605 Member For: 17y 19d Gender: Male Location: brisbane Posted 08/06/08 10:35 AM Author Share Posted 08/06/08 10:35 AM (edited) damnit.double post. Edited 08/06/08 10:40 AM by bluprinturbo Link to comment https://www.fordxr6turbo.com/forum/topic/46437-c4-or-turbo-400/page/2/#findComment-690076 Share on other sites More sharing options...
IceMyButt Link Member 421 Member For: 20y 11m 28d Gender: Male Location: Sydney Posted 08/06/08 03:26 PM Share Posted 08/06/08 03:26 PM Perfect to drive daily, just gotta make sure you keep them well cooled with a good oil cooler setup. Initial conversion was about $9K for box and mods to install. Link to comment https://www.fordxr6turbo.com/forum/topic/46437-c4-or-turbo-400/page/2/#findComment-690264 Share on other sites More sharing options...
DUS12 Member 471 Member For: 17y 10m 25d Posted 08/06/08 11:45 PM Share Posted 08/06/08 11:45 PM als race glides did my c4, yes th400 are stronger but are also much larger, heavier and take a lot mor power to drive, the conversion is easy, I pretty sur your tail shaft will bolt up,(I had to modify mine cause it was a manual) cross member is easy, the box I got is transbraked but I havent even hooked it up yet because of a great converter, although the new 1200hp turbo should fix that. I would be ringing al and he can give you a price on conversion bellhousing box and converter, Link to comment https://www.fordxr6turbo.com/forum/topic/46437-c4-or-turbo-400/page/2/#findComment-690307 Share on other sites More sharing options...
