Cabin Heater
CJ_AK
  • Member For: 19y 8m 8d
you may be able to clear a few things up for us then brute. if I can hear the motor going and temp doesn't change, that'd be the mixer shaft hey?
but no sound at all if probably a knackered him right?
cheers!
  • Here since the start...
  • Member For: 21y 10m 5d
It was suggested that I 'burp' the system. Meaning I drain the system again and refill with the motor on and the heater and fan on full, in order to open the heater hoses etc...
In a single zone heating system the core is always open so the above doesn't apply in this case.
  • Member For: 17y 1m 9d
Guys I need some help
I have an 03 xr6T, about 110 kays. I recently serviced it doing an oil change, oil filter, air filter, coolant flush and refill.
Only mods are a 10 psi stage 1 custom tune, I always run the 8 psi stage 2 though.
After the service, the heater stopped working!! The fan works fine, A/C is fine everything really is perfect accept it will not blow warm air.
Have just tried it this afternoon, no success.
Guys I could really use your expertise and advice on this one.
Thanks
Yeah mate I would check your heater core
  • Oh look.... a real car, with no hair dryer
  • Member For: 18y 6m 20d
Does anyone out there have an 03 model with a "working" heater???
I sure as hell dont!
Edited by mercuryturbo
cheers!
xr06t
that's the case with me, no noises = HIM stuffed grrrrrrrrrrr
  • Member For: 17y 3m 5d
if this problem is so common, I would be asking Ford to foot the bill. Obviously the heating mechanism is not of merchantible quality. Heaters should last much longer then 4 or 5 years, it's not like they have such a hard job to do.
you have a good point but it was so hard to deal with them when the car was under warranty, I really dont want to have to go back there!
I'd actually rather attempt to take dash out with no beers than go down there!!
