ETM Member 1,194 Member For: 17y 11m 17d Gender: Male Location: syd south Posted 09/06/08 06:14 AM Share Posted 09/06/08 06:14 AM http://cgi.ebay.com.au/CROW-CAMS-F6-FPV-XR...1QQcmdZViewItem Link to comment Share on other sites More sharing options...
7MA61 Member 471 Member For: 17y 6m 18d Gender: Male Location: Sydney Posted 09/06/08 07:11 AM Share Posted 09/06/08 07:11 AM (edited) Agreed I had a set of cams & valve springs delivered to my door from the US last year for $950.If yo are paying $3k just for the cams you are getting ripped. Edited 09/06/08 07:12 AM by 7MA61 Link to comment Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 6m 12d Gender: Male Location: Broady, Melbourne Posted 09/06/08 02:23 PM Share Posted 09/06/08 02:23 PM Ripped big-time. WELL under $2k. In fact, around $1500 fitted should be about right. Link to comment Share on other sites More sharing options...
INFLYT Donating Members 784 Member For: 18y 7m 20d Gender: Male Location: N.S.W, Sydney Posted 09/06/08 03:02 PM Share Posted 09/06/08 03:02 PM I made a thread here about a well priced Camshaft deal. Link to comment Share on other sites More sharing options...
Gavin.K Member 288 Member For: 19y 8m 18d Gender: Male Location: sydney Posted 09/06/08 11:06 PM Share Posted 09/06/08 11:06 PM Yes you can buy the valve springs from about $286 from Nizpro.You should be able get the cams from $650-$700 (retail for the cams is $900.00 + gst + freight) depending on were you get them from.All you need then is to get your tunner to fit and dial them in. The cams will come spec sheet and there is also three stages. You guys should go for stage two or three. Stage two goes for the midrange power. Real useable power for on the street were stage three is for high end power only. It is designed for track use or dyno work it has been known to be extreamly lumpy at low revs thus tending to be a bit of a dog to drive on the street. Link to comment Share on other sites More sharing options...
forced Member 97 Member For: 19y 2m 2d Gender: Male Location: south australia Posted 10/06/08 08:51 AM Share Posted 10/06/08 08:51 AM hi try atomic cams in my ute first set didnt work and the second set gave me mid range increase but top end loss of 20kw@rw so put back stock ones .really not needed till u make 450rwkw plus.needed more power add bigger turbo and more boost that should work Link to comment Share on other sites More sharing options...
Gavin.K Member 288 Member For: 19y 8m 18d Gender: Male Location: sydney Posted 11/06/08 12:31 AM Share Posted 11/06/08 12:31 AM I guess you have hit the nail on the head there forced. The stage two cams will give you mid range power that you will find to be useable as a spirited street driver. Yes a bigger turbo will give you more top end power and lets face it how driveable is a xr6t with 400+ rwkw anyway. They are great down the drag strip but as far as usable power you would probley find that the car is much more functional with mid-range power gain rather than 20rwkw's right up the top.GK Link to comment Share on other sites More sharing options...
