  • Fastest Taxi In Melbourne
  • Member For: 19y 1m 13d
  AaronXR said:
Something has come off/loose out the back of your ICC, when I pulled mine I lost pretty much everything including my speedo/rpm, was quiet odd driving to the auto electrician with nothing working, quiet dangerous too
edit: My ICC did work though, just nothing else.
yeh it could be the icc, ill take it to ford tomorrow for them to have a look at,
I just hope they cover it under warranty :roflmbo:
  • 1 year later...
  • Member For: 16y 3m
The exact same thing is hapening with my car. My issue is I don't have books, so I don't know which fuse is which. Can someone be a champ and post a diagram of the fuse panel. Thanks heaps.
  • Member For: 17y 2m 23d
Yes it is common.... If the fuses are ok it will most likely be the combo switch. We have about 50 of the things in our warranty shed for this same reason,so very common for sure.
  • 3 weeks later...
  • Member For: 18y 1m 19d
  On 28/11/2009 at 9:58 AM, 20pounds said:
has a broken wire in the blinker arm 200% sure same thing happened to my mates bf and he was told it was common
[/quote
As 20pounds said.. I too believe this is the cause. I had the EXACT same symptoms as you a few months ago. If you jiggle your indicator stalk around and your lights return to norm and then goes.. you have located the prob. This is a common problem in the Ba/Bf's. I don't think Ford mad the wires long enough. :stirthepot: Your service centre should fix it under warranty.
