INPURSUIT Fastest Taxi In Melbourne Donating Members 701 Member For: 18y 8m 9d Gender: Male Location: Melbourne Posted 04/06/08 01:07 PM Author Share Posted 04/06/08 01:07 PM Something has come off/loose out the back of your ICC, when I pulled mine I lost pretty much everything including my speedo/rpm, was quiet odd driving to the auto electrician with nothing working, quiet dangerous tooedit: My ICC did work though, just nothing else.yeh it could be the icc, ill take it to ford tomorrow for them to have a look at,I just hope they cover it under warranty Link to comment Share on other sites More sharing options...
LUMO Donating Members 476 Member For: 17y 9m 5d Gender: Male Location: SYDNEY Posted 04/06/08 02:11 PM Share Posted 04/06/08 02:11 PM Im with AaronXR, that is also possible, they may have connected everything but not clipped in properly.. Link to comment Share on other sites More sharing options...
anthb86 Member 11 Member For: 15y 9m 27d Gender: Male Location: Mordialloc, VIC Posted 28/11/09 09:44 AM Share Posted 28/11/09 09:44 AM The exact same thing is hapening with my car. My issue is I don't have books, so I don't know which fuse is which. Can someone be a champ and post a diagram of the fuse panel. Thanks heaps. Link to comment Share on other sites More sharing options...
20pounds Member 180 Member For: 16y 1m 25d Gender: Male Posted 28/11/09 09:58 AM Share Posted 28/11/09 09:58 AM has a broken wire in the blinker arm 200% sure same thing happened to my mates bf and he was told it was common Link to comment Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 16y 9m 19d Posted 28/11/09 11:57 AM Share Posted 28/11/09 11:57 AM Yes it is common.... If the fuses are ok it will most likely be the combo switch. We have about 50 of the things in our warranty shed for this same reason,so very common for sure. Link to comment Share on other sites More sharing options...
alpha Member 266 Member For: 17y 8m 15d Gender: Male Location: Perth Posted 15/12/09 02:17 PM Share Posted 15/12/09 02:17 PM has a broken wire in the blinker arm 200% sure same thing happened to my mates bf and he was told it was common[/quoteAs 20pounds said.. I too believe this is the cause. I had the EXACT same symptoms as you a few months ago. If you jiggle your indicator stalk around and your lights return to norm and then goes.. you have located the prob. This is a common problem in the Ba/Bf's. I don't think Ford mad the wires long enough. Your service centre should fix it under warranty. Link to comment Share on other sites More sharing options...
