Dash Lights,parkers And Rear Lights Not Working!
INPURSUIT
  • Fastest Taxi In Melbourne
  • Member For: 18y 8m 9d
Something has come off/loose out the back of your ICC, when I pulled mine I lost pretty much everything including my speedo/rpm, was quiet odd driving to the auto electrician with nothing working, quiet dangerous too
edit: My ICC did work though, just nothing else.
yeh it could be the icc, ill take it to ford tomorrow for them to have a look at,
I just hope they cover it under warranty :roflmbo:
  • 1 year later...
  • Member For: 15y 9m 27d
The exact same thing is hapening with my car. My issue is I don't have books, so I don't know which fuse is which. Can someone be a champ and post a diagram of the fuse panel. Thanks heaps.
  • 3 weeks later...
  • Member For: 17y 8m 15d
has a broken wire in the blinker arm 200% sure same thing happened to my mates bf and he was told it was common
[/quote
As 20pounds said.. I too believe this is the cause. I had the EXACT same symptoms as you a few months ago. If you jiggle your indicator stalk around and your lights return to norm and then goes.. you have located the prob. This is a common problem in the Ba/Bf's. I don't think Ford mad the wires long enough. :stirthepot: Your service centre should fix it under warranty.
