kissy Member 132 Member For: 18y 2m 28d Gender: Male Location: S.E. Melbourne Posted 11/06/08 01:06 AM Author Share Posted 11/06/08 01:06 AM Ok what I think I’ve narrowed the problem down to is a faulty O2 sensor, as the surging only happens when the car is cruising, the car is using closed cycle cruise mode. So if the O2 sensor is intermediately giving out the wrong voltage it will cause the engine to run to lean or rich causing the surging and loss of power.So on the weekend I’m going to replace the O2 sensor and see if that fix’s the problem. Link to comment https://www.fordxr6turbo.com/forum/topic/46294-surging-at-cruise-speeds/page/2/#findComment-691446 Share on other sites More sharing options...
SLVRXRT Member 28 Member For: 19y 9m 24d Gender: Male Posted 11/06/08 01:34 AM Share Posted 11/06/08 01:34 AM I had the same problem with my Rex a while back. It was a faulty O2 sensor. Link to comment https://www.fordxr6turbo.com/forum/topic/46294-surging-at-cruise-speeds/page/2/#findComment-691463 Share on other sites More sharing options...
kissy Member 132 Member For: 18y 2m 28d Gender: Male Location: S.E. Melbourne Posted 15/06/08 11:55 AM Author Share Posted 15/06/08 11:55 AM Well it turns out it was the oxy sensor, the wire's were caught under the heat shield and rubbed up against the exhaust manifold. this caused one of the wires to wear all the way down to the conductor. This wire also happened to be the signal wire!! So the signal wire was earthing out against the manifold, thus the ecu getting the wrong signal! Link to comment https://www.fordxr6turbo.com/forum/topic/46294-surging-at-cruise-speeds/page/2/#findComment-693579 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 15d Gender: Male Location: @ my laptop Posted 15/06/08 11:58 AM Share Posted 15/06/08 11:58 AM Good to see you get it sorted out, good on ya for reporting back what the problem was Link to comment https://www.fordxr6turbo.com/forum/topic/46294-surging-at-cruise-speeds/page/2/#findComment-693584 Share on other sites More sharing options...
firie386 Member 6 Member For: 17y 6m 10d Posted 08/12/08 02:44 AM Share Posted 08/12/08 02:44 AM kissy said: Well it turns out it was the oxy sensor, the wire's were caught under the heat shield and rubbed up against the exhaust manifold. this caused one of the wires to wear all the way down to the conductor. This wire also happened to be the signal wire!! So the signal wire was earthing out against the manifold, thus the ecu getting the wrong signal!I've got this Problem on a 2002 BA XR6T. I have had it to ford quite a few times and they can't pinpoint it, although we have changed 3 coil Packs, TPS. They checked fuel pressure,turbo the coils again, reflashed it etcOccassionally car stalls completely and check engine light comes on. It happens when cruising or with min throttle. This is particularly the case after coasting and then apply min throttle. Codes logged are running too rich & too lean.Is there a code logged for oxy sensor gone?Any ideas much appreciated Link to comment https://www.fordxr6turbo.com/forum/topic/46294-surging-at-cruise-speeds/page/2/#findComment-782699 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 4d Gender: Male Location: SW Sydney Posted 08/12/08 02:52 AM Share Posted 08/12/08 02:52 AM Good chance it is the Oxygen Sensor Firie, considering the O2 sensor can control the mixtures, probably worth changing anyway Link to comment https://www.fordxr6turbo.com/forum/topic/46294-surging-at-cruise-speeds/page/2/#findComment-782705 Share on other sites More sharing options...
