xrturbomatty Member 79 Member For: 16y 11m 4d Posted 06/06/08 04:54 AM Author Share Posted 06/06/08 04:54 AM Hey after looking at the pictures I still dont understand where it is and I cant find any 8mm bolts near the throttle body Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 8d Gender: Male Location: Perth Posted 06/06/08 05:39 AM Share Posted 06/06/08 05:39 AM that guide is for and E series not a B series Falcon. Good write up though Link to comment Share on other sites More sharing options...
2MUCHKW Member 350 Member For: 18y 10m 12d Posted 06/06/08 10:14 AM Share Posted 06/06/08 10:14 AM Hi guys! noticed a few people with the dreaded rough idle.Also interesting to note a few are running K&N oiled air filters.I have heard of others spending a fortune trying to fix rough idle & this cost youNothing but time.Also may fix that rough change in some autos?Have a go it may also work for you- Have a read below. The Idle Speed Controller Valve, or otherwise known as the Idle Air Bypass System, is responsible for maintaining a smooth, and consistent idle, under different Engine Loads, and temperatures.It does this by allowing a certain amount of air, to bypass the Throttle Body Butterfly, thereby increasing the amount of air entering the engine, under certain conditions, thereby increasing Engine RPM.The Idle speed control valve is controlled by the EEC-V Engine Management system, and is a spring loaded stepped motor, that opens a small valve, that allows air to flow. It is actually quite common for this valve to get gummed up and slighty jammed, by carbon deposits, oil, and other foreign materials.This is especially the case if an aftermarket air cleaner, that is oil based (Such as K & N air Filters), as the Oil is slowly sucked in to the Idle speed controller, and slowly blocks off, and jams the air passage and Valve.Symptoms of a jammed, or dirty Idle Speed Controller include, · 1) Poor idle quality in cold temperatures. · 2) Engine stalling under load (Eg Power steering operation, Air Conditioning, etc), under closed throttle (Idle) conditions. · 3) Rough Gear changes on Automatics when changing from second, to first gear, (Engine speed surging). · 4) Engine RPM surging at idle, for no reason. (I.E. Engine increasing RPM to greater than 1000rpm, for no apparent reason).Cleaning the Idle Speed ControllerThe Idle speed controller can be easily cleaned, and is recommended if the above symptoms exist.Who posted this?? :wacko: :wacko: :wacko: The BA-BF and new FG dont have an Idle Speed Control Valve BA - FG Falcons all have fly by wire throttle in which the PCM finely adjusts the main throttle body butterfly position to control idle speed!!!!cheers Link to comment Share on other sites More sharing options...
dave1982 New Member 1 Member For: 7y Posted 03/03/18 08:33 AM Share Posted 03/03/18 08:33 AM I have a ba and isnt the idle control valve on the side of the throttle body I have this rough idle problem and it is the same problem as when u take the wire closet to the front of the car off the throttle body Link to comment Share on other sites More sharing options...
