Help Install
Doolz
  • Member For: 17y 3m
Hey Everyone
I have finally received my bits and pieces to install my new set of brakes on the front. Here is what I got.
1. BA PBR RED PERFORMANCE CALIPER AND PADS TO SUIT 325MM ROTOR (SAME AS FORD PREMIUM BRAKES)
2. FRONT 4000 SERIES ROTORS 325MM TO SUIT PBR PERFORMANCE / FORD PREMIUM CALIPERS CROSS DRILLED AND SLOTTED
3. Braided hose
I was looking at installing this on the weekend. I looked at the PBR website and there are some pretty simple fitting instructions. When I was speaking to someone from PBR, he said that there might be a bracket required to fit these on. I ordered the braided hose from Melb and the dude said that there is a special connection from the brake line to the above calipers. He sent me the right connection I believe.
I was just wondering if anyone has installed this before and can tell me how easy/ difficult it is. I am hoping that it will be almost a direct replacement. I have 18" wheels so hopefully there is enough room for them (require 18"+ apparently).
I hope that it is relatively easy. I have all the right tools and have bled brake lines before so I am pretty confident with that. Any suggestion from anyone?
Edited by Doolz
  • <put funny sh*t here>
  • Member For: 18y 3m 5d
Sorry cant really provide much input for you, but if you can take lots of snaps as your doing it that would be great as I'll be swapping rotors/brake line as soon as I get my ass in gear and buy them.
