Changing Front Brakes
cv8-r350
  • Member For: 16y 10m 7d
I have an F6 Ba with the standard brakes, FPV blue calipers (too small) and I wanna upgrade the rotors and calipers. I was wondering if I could go cheap and buy new front ones only and put the original FPV fronts on the rear and get rid off the rear ones
cheers
Edited by cv8-r350
  • Member For: 17y 7m 21d
yes you can replace the fronts very easily (I recommend AP Racing CP5400) I have them on my T, along with 2 peice rotors, did some 100kph Brake testing at an advanced drive day, braking from 100kph to a stop.
Compared to a newish GT that was there with 4 piston brembos my car pulled up in a marginally shorter distance (could also be due to the better tyres I have)
He had the Brembo 4 piston fronts with the PBR rears. My rear brakes are standard.
Along with a sprint meeting a few weeks ago, continual punishment from high speed, no fade whatsoever.
I dont think you can transfer the front calipers to the rear of the car, even with brackets / adaptors etc. also consider the ECU systems... ABS / traction systems etc being calibrated for the slide caliper setup that's fitted standard.
