groper Member 611 Member For: 18y 3m 1d Posted 08/06/08 09:50 AM Author Share Posted 08/06/08 09:50 AM (edited) well done guys!!!!!!!!!!I had a similar thing on my manual a year and a half ago..... worked basically the same way... keep your foot flat to the floor and change gears... it did not rev out past the revs set in via the edit, and changing was a actually fun in this manner. have you guys done something better then the wog did when he was doing it? or is the flat shift very similar to what he was doing? if it is better in what way?the launch control is totally unchartered waters though and a big thumbs up on that one as well!!!!!!!!!!!!!!!!!!! its times like these I wish the manual was still modified.good luck at the track!!we spoke to the wog about it, and sure you can set the factory limiter in the pcm to catch the revs from over revving, you can even set it so it only activates when you push the clutch in... but like I said, it pulls fuel and closes the throttle, it doesnt cut spark. Therefore you can still flatshift without fear of over revving, but you still loose boost between shifts and get the lag.F6UTE and guys like that drove themselves around this problem by shifting faster than superman could blow his load, but I dont really wanna do that to my gearbox and probably dont have level of skill these guys have either... with this, anybody can do it easily and safely.I spoke to F6UTE and asked his advice on how to launch hard so I could run a decent time. His advice was to have a good clutch and launch from 4800rpm. So I tried this a few times and almost blew up my clutch in the process. This is why I started to look into it and find a better way, so I didnt have to abuse my clutch to launch hard. Edited 08/06/08 09:56 AM by groper Link to comment https://www.fordxr6turbo.com/forum/topic/45735-wanna-be-able-to-launch-a-manual-like-this/page/8/#findComment-690028 Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 10m 18d Gender: Male Location: Nrth Qld Posted 08/06/08 10:04 AM Share Posted 08/06/08 10:04 AM So how do we do it?how to do it.mp3 - 0.04MB Link to comment https://www.fordxr6turbo.com/forum/topic/45735-wanna-be-able-to-launch-a-manual-like-this/page/8/#findComment-690042 Share on other sites More sharing options...
fordboy1981 Donating Members 2,075 Member For: 22y 3m 14d Gender: Male Location: Sydney, NSW Posted 08/06/08 10:06 AM Share Posted 08/06/08 10:06 AM how to do it.mp3 - 0.04MByou idiot... Link to comment https://www.fordxr6turbo.com/forum/topic/45735-wanna-be-able-to-launch-a-manual-like-this/page/8/#findComment-690046 Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 10m 18d Gender: Male Location: Nrth Qld Posted 08/06/08 10:09 AM Share Posted 08/06/08 10:09 AM No mate. Im a boneafied moron.As mentioned before. Link to comment https://www.fordxr6turbo.com/forum/topic/45735-wanna-be-able-to-launch-a-manual-like-this/page/8/#findComment-690050 Share on other sites More sharing options...
groper Member 611 Member For: 18y 3m 1d Posted 08/06/08 10:18 AM Author Share Posted 08/06/08 10:18 AM (edited) This is how you have to shift in order to avoid lag using just edit alone... watch the first vid in the first post...http://www.fordxr6turbo.com/forum/index.ph...1&hl=manual Edited 08/06/08 10:23 AM by groper Link to comment https://www.fordxr6turbo.com/forum/topic/45735-wanna-be-able-to-launch-a-manual-like-this/page/8/#findComment-690059 Share on other sites More sharing options...
TOM1111 Member 631 Member For: 17y 9m 4d Gender: Male Location: newcastle Posted 08/06/08 10:20 AM Share Posted 08/06/08 10:20 AM that link goes no where Link to comment https://www.fordxr6turbo.com/forum/topic/45735-wanna-be-able-to-launch-a-manual-like-this/page/8/#findComment-690063 Share on other sites More sharing options...
groper Member 611 Member For: 18y 3m 1d Posted 08/06/08 10:23 AM Author Share Posted 08/06/08 10:23 AM fixed Link to comment https://www.fordxr6turbo.com/forum/topic/45735-wanna-be-able-to-launch-a-manual-like-this/page/8/#findComment-690065 Share on other sites More sharing options...
2MUCHKW Member 350 Member For: 19y 13d Posted 08/06/08 10:50 AM Share Posted 08/06/08 10:50 AM on this vid I set the flat shift limit to 5000rpm. youd swear its an auto yeah? but I can assure you its a manual... I know of a Cairns BF F6 ZF auto that'd eat your slow ute for breakfast Link to comment https://www.fordxr6turbo.com/forum/topic/45735-wanna-be-able-to-launch-a-manual-like-this/page/8/#findComment-690086 Share on other sites More sharing options...
groper Member 611 Member For: 18y 3m 1d Posted 08/06/08 10:53 AM Author Share Posted 08/06/08 10:53 AM we shall see at the strip then wont we? oh I forgot, you cant fit MT ET streets over your brakes can you? Link to comment https://www.fordxr6turbo.com/forum/topic/45735-wanna-be-able-to-launch-a-manual-like-this/page/8/#findComment-690090 Share on other sites More sharing options...
jetute Donating Members 4,553 Member For: 21y 3m 1d Gender: Male Location: brisbane Posted 08/06/08 10:55 AM Share Posted 08/06/08 10:55 AM This is how you have to shift in order to avoid lag using just edit alone... watch the first vid in the first post...http://www.fordxr6turbo.com/forum/index.ph...1&hl=manualthat was just a tune wasnt it?? he didnt have a set up at that stage with the revs set for the flat shift did he?? when are you going to the drags?? keen to see how the launch control works and what 60 foot times it will enable... and what times you run!!exciting times ahead Link to comment https://www.fordxr6turbo.com/forum/topic/45735-wanna-be-able-to-launch-a-manual-like-this/page/8/#findComment-690092 Share on other sites More sharing options...
