Oil In Water Coolant
Hectic Dude
  • Into the laaaake
  • Member For: 17y 8m 6d
I wouldnt be saying phew to that..... If your cars auto, you may have now wound up with an Auto full of water and an engine/cooling system full of auto trans fluid...... that's bad new......
Otherwise you may have a blown head gasket?
Edited by hanra
  • Sucker
  • Moderating Team
  • Member For: 20y 9m 26d
Did they advise that you do not drive the vehicle until it's fixed :spoton:
Like Hanra said - might be a common issue but it's nothing to feel relieved about! :Doh:
  • 10 months later...
  • Member For: 15y 11m 2d
doesnt sound like a good problem.. I have a small crack in my head gaste just after I blew my turbo..
was wondering do you know wat this would cost ?
can it be done at home ?
cheers
could I get a pm plz
Edited by turk_pig
  • 1 year later...
  • Member For: 14y 8m 12d
Hi Guys,
Went for an oil change today and the guys found oil in the water coolant... Obviously not good news.
Will be taking to Ford on Monday.
Question is - has anybody else with an F6 (or XR6 Turbo) had this problem?
Regards,
Luke
Hi there, I just purchased an XR6 turbo and had dealt with this problem yesterday. The issue is that there is a transmission cooler located in the standard radiator. This internal transmission cooler blows and releases transmission fluid into your radiator. This needs to be replaced ASAP. You need to get a new radiator fitted - preferably with a stainless steel transmission cooler. The gearbox needs as much cooling as possible so it's best to leave this and the external one if fitted. You will also need to change top and bottom radiator hoses (as they have had oil through them)and get the gear box serviced ASAP and flushed with new transmission fluid added.
  • UNDERCOAT CRUISER!!!
  • Member For: 16y 1m 3d
I had the same issue as hectic dude had,my problem was the external engine oil cooler had a small crack in the pipe as it is also watercooled,would suck the oil into the coolant tank.replaced oil cooler all sweet now!
  • 570Nm @1800rpm
  • Member For: 21y 4m 30d
This was only a problem with BAs with 4 speed auto. The car in his picture is a BA Typhoon and they only came out as a manual.
