Goliath Member 383 Member For: 14y 9m 16d Gender: Male Location: Sydney Posted 27/02/12 04:32 AM Share Posted 27/02/12 04:32 AM On 27/02/2012 at 2:35 AM, ssstututu said: Yer so blocked my bov off and u can only hear the littlest flutter at high revs once u change gears. Bit of a let down maybe I should just vent the stock oneSent from my left nut using my right handHave you tried just backing of the accelerator? I removed the BOV yesterday and could hear it quite easily. Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/9/#findComment-1202328 Share on other sites More sharing options...
rbjet Skid Machine Donating Members 1,640 Member For: 13y 11m 7d Gender: Male Posted 27/02/12 04:41 AM Share Posted 27/02/12 04:41 AM FG's run more boost than BA's do. Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/9/#findComment-1202335 Share on other sites More sharing options...
.BLKPHN. Bronze Donating Members 283 Member For: 14y 2m 9d Gender: Male Posted 27/02/12 05:39 AM Share Posted 27/02/12 05:39 AM If you block the bov should be able to hear it easy ayy Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/9/#findComment-1202364 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 9m 11d Gender: Not Telling Posted 27/02/12 05:56 AM Share Posted 27/02/12 05:56 AM (edited) On 27/02/2012 at 2:35 AM, ssstututu said: Yer so blocked my bov off and u can only hear the littlest flutter at high revs once u change gears. Bit of a let down maybe I should just vent the stock oneSent from my left nut using my right handMaybe just check that all piping is is nice and tight and no split connectors. I only have stock boost and you can hear mine no trouble. I might add to reduce under bonnet temps I removed the hoodlining and the rubber rear bonnet strip (running across top of firewall) to allow air to escape, so I'm sure this adds to the sound. Cheers Edited 27/02/12 05:58 AM by Impellor Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/9/#findComment-1202375 Share on other sites More sharing options...
ssstututu Member 88 Member For: 13y 4m 17d Posted 27/02/12 07:55 AM Share Posted 27/02/12 07:55 AM I noticed my clamps where quite loose so did tigthen them up but I might remove the headliner and the rubber seal also do u have a k&n filter im still running all the stock gear this mod was my first Sent from my left nut using my right hand Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/9/#findComment-1202468 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 9m 11d Gender: Not Telling Posted 27/02/12 08:23 AM Share Posted 27/02/12 08:23 AM (edited) On 27/02/2012 at 7:55 AM, ssstututu said: I noticed my clamps where quite loose so did tigthen them up but I might remove the headliner and the rubber seal also do u have a k&n filter im still running all the stock gear this mod was my firstSent from my left nut using my right handYeah running K&N and a big arse pipe. The pics should give you an idea. In 1 there is the pipe which is 150mm aluminum ducting that I flattened and cut out of the lower section on the airbox. The other is where I followed the rubber mounted on bonnet and trimmed away the snorkel with the grinder, Cheers http://s1191.photobu...mpellor/Intake/ Edited 27/02/12 08:26 AM by Impellor Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/9/#findComment-1202484 Share on other sites More sharing options...
ssstututu Member 88 Member For: 13y 4m 17d Posted 27/02/12 12:43 PM Share Posted 27/02/12 12:43 PM will be doin this then impellor Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/9/#findComment-1202764 Share on other sites More sharing options...
