  • Member For: 14y 8m 29d
  • Gender: Not Telling
I've said it a few times that my car feels like it ran better with the bov blocked over vented. Yet to compare on a manual but I think my cheap kompact is starting to leak so will soon find out.
Dillz, this particular mod from my understanding, is far more beneficial for Manual than Auto. Mate give it a go. You can always change it back. But I'm betting you don't. Cheers
After all this talk, I'm going to put my stock bov back on tonight, just to see if there's any difference since the tune since the Kompat one is adjustable, so it may not be functioning as well as it could (I could have it set up wrong since I don't really know much about setting them up)
Just to clarify, this mod is really only advantageous in a manual. From my understanding the Auto doesn't suffer the same lag issues as the manual when changing gears. But hey, give it a go, you may find an improvement. Cheers
  • Member For: 14y 3m 8d
So to summarize, get an auto cos its better with or without a BOV.
  • Member For: 13y 4m 4d
when u put a dose pipe on and only remove that pipe from the turbo to the cross over are u ment to block that off? and can u run a pipe down rather than up? anyone got pics
Sent from my left nut using my right hand
Technically it should be blocked if still running the BOV, because you are now venting to atmosphere. Once you run a dose pipe you make the entire factory intake system obsolete. There crossover piping is separate, so the only reason to block is to stop stuff going into. Cheers
  • 2 weeks later...
  • Member For: 14y 1m 12d
I noticed an improvement blocking the system from a stock bov.
but I would like to see the difference of blocked vs an aftermarket one. Seeing that the cardboard stock bov was probably leaking boost. maybe just getting a better bov would get the improvement on throttle response and lag?
but due to uneducated coppers a few other guys in adelaide have been defected for Blow of valves when they dont in fact have them. if someone hears a dose from a turbo car they think. "that's the bov making that noise. so its possible to get defected for having an illegally vented bov when you in fact dont have one at all.
The people that have tried arguing that point to the cops didnt work either.
seems f*cked to me that not having a blow off valve must be legal due to some cars not having them from factory but you can get defected all the same because people dont even know what they are.
  • Skid Machine
  • Member For: 13y 10m 25d
I'm guessing your still running standard boost?
That's pretty much all you'll get. Once the boost is up'd then things will change.
