Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 11m 5d Gender: Male Location: Melbourne Posted 24/01/09 07:31 AM Share Posted 24/01/09 07:31 AM (edited) Superdan said: that's no reason to be nasty to me!I wasn't talking to you dude, was talkin about the OP. So take it easy.. Edited 24/01/09 07:31 AM by Dillz Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/4/#findComment-809502 Share on other sites More sharing options...
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 17y 8m 11d Gender: Male Location: Perff, WA Posted 24/01/09 07:36 AM Share Posted 24/01/09 07:36 AM que?? Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/4/#findComment-809506 Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 3m Posted 25/01/09 11:46 AM Share Posted 25/01/09 11:46 AM The stubbie cap works a treat as you cant tell anythings been messed with. Just pull the large hose off the blow off valve on the pressure side,put stubbie cap on blow off valve then push large hose back on. Leave the vac hose on it as it doesnt matter if it opens cos the passage is blocked and then you have a flutter or should I say you have compressor surge noise when you back off. Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/4/#findComment-810238 Share on other sites More sharing options...
Smitty New Member 16 Member For: 16y 7m 1d Posted 25/01/09 11:57 AM Share Posted 25/01/09 11:57 AM I would have to say this would be the most dodgy, riced up how to thread on this forum Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/4/#findComment-810250 Share on other sites More sharing options...
djextreme Member 112 Member For: 15y 11m 27d Gender: Male Location: Melb Posted 16/11/09 10:59 AM Share Posted 16/11/09 10:59 AM what would happen if u vented the factory BOV to atmosphere????wat does it sounds like? Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/4/#findComment-954476 Share on other sites More sharing options...
on dubs Member 132 Member For: 16y 8m 3d Gender: Male Location: Gawler, SA Posted 19/11/09 12:48 PM Share Posted 19/11/09 12:48 PM sounds pathetic on stock boost. Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/4/#findComment-955591 Share on other sites More sharing options...
84DAU Member 23 Member For: 15y 3m 24d Gender: Male Location: Brisbane Posted 07/01/10 09:49 AM Share Posted 07/01/10 09:49 AM isnt it possible to just disconnect the vac line from manifold to BOV... now the BOV wont get the needed vacuum to open.why must the BOV be removed and the inlets blocked? Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/4/#findComment-968902 Share on other sites More sharing options...
Bigkeels Throbbing Member Donating Members 594 Member For: 16y 2m 25d Gender: Male Location: Victoria Posted 13/01/10 11:08 PM Share Posted 13/01/10 11:08 PM Anyone had any luck finding some 1'' rubber hose end caps? The biggest size I can find is 3/4'' and I dont really want to have to use a chair stopper.. Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/4/#findComment-970635 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 10m 11d Gender: Male Location: Earth Posted 14/01/10 12:23 AM Share Posted 14/01/10 12:23 AM What's wrong with a chair stopper?If you get the right ones they are thicker than most automotive plugs anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/4/#findComment-970648 Share on other sites More sharing options...
Bigkeels Throbbing Member Donating Members 594 Member For: 16y 2m 25d Gender: Male Location: Victoria Posted 14/01/10 06:08 AM Share Posted 14/01/10 06:08 AM (edited) There not designed to put up with the heat in the engine bay. If all else fails I'll get one, but I'd feel more comfortable with a proper stopper which is designed to cope with the heat of the engine bay.And seeing this picture makes me worry. Edited 14/01/10 06:12 AM by Bigkeels Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/4/#findComment-970745 Share on other sites More sharing options...
