R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 5m Gender: Male Location: Melbourne Posted 17/05/08 11:02 AM Share Posted 17/05/08 11:02 AM A screw just the right size works every time. Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/2/#findComment-677924 Share on other sites More sharing options...
Grudgee Every Mod's Favourite Member Member 1,496 Member For: 17y 1m 25d Gender: Male Location: Melbourne Posted 18/05/08 02:24 AM Share Posted 18/05/08 02:24 AM (edited) R-SPEC said: Running a dose pipe without removing the battery and making an airbox for the filter means that the intake temps are about as hot as the engine. Plus, if you block the BOV to make the dose/flutter bigger, it has been known to damage turbos. (Not necessarily our ones...)So the good old dose pipe setup (without proper airbox mod) hinders performance and has a high pitched alarm to alert all nearby motorist that you're a show, not go, type of guy? I'd give the flutter setup a go, as it seems like an easy tweak that can be reverted to stock quite easily, but I'm simple and don't know how to work out what's what in the TT engine bay. Edited 18/05/08 02:29 AM by Grudgee Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/2/#findComment-678164 Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 5m Gender: Male Location: Melbourne Posted 18/05/08 02:30 AM Share Posted 18/05/08 02:30 AM (edited) If it makes it feel slower, it's probably just a bit of heatsoak. It wouldn't lose enough power so that a Jeep could kick your ass hahahaA Territory Turbo with a dose pipe... That would be hilarious on a cruise Edited 18/05/08 02:31 AM by R-SPEC Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/2/#findComment-678169 Share on other sites More sharing options...
Grudgee Every Mod's Favourite Member Member 1,496 Member For: 17y 1m 25d Gender: Male Location: Melbourne Posted 18/05/08 02:34 AM Share Posted 18/05/08 02:34 AM If someone had the patience to hook it up, I'd do it for sh*ts n' giggles. You volunteering RSPEC? What goodies would be required? Just the pipe, pod filter and some clamps/hose? Couple hundred bucks for some laughs is well worth it. Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/2/#findComment-678173 Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 5m Gender: Male Location: Melbourne Posted 18/05/08 02:40 AM Share Posted 18/05/08 02:40 AM All depends on how hard it is to block your BOV and the room for the pipe.From what I've seen, that top mount cooler would make things real messy! Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/2/#findComment-678179 Share on other sites More sharing options...
Grudgee Every Mod's Favourite Member Member 1,496 Member For: 17y 1m 25d Gender: Male Location: Melbourne Posted 18/05/08 03:20 AM Share Posted 18/05/08 03:20 AM R-SPEC said: All depends on how hard it is to block your BOV and the room for the pipe.From what I've seen, that top mount cooler would make things real messy!You didn't answer the question! Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/2/#findComment-678194 Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 5m Gender: Male Location: Melbourne Posted 18/05/08 04:58 AM Share Posted 18/05/08 04:58 AM R-SPEC said: You need a flathead screw driver, a 10mil hex thingy, a pair of long nose plyers and a 1" rubber chair leg stopper thingy.You need these things, plus a 90° metal pipe, a 3" silicone hose, a can of Coke and a smile.And the answer is yes, IF it's not more complicated than a sedan... Riddle me that Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/2/#findComment-678238 Share on other sites More sharing options...
Maximus Member 1,627 Member For: 18y 1m 20d Gender: Male Location: Slip Sliding Away Posted 18/05/08 09:34 AM Share Posted 18/05/08 09:34 AM Funnt Dose that I had to share._eyvtYexo3k xVS2v0mLHE8 Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/2/#findComment-678319 Share on other sites More sharing options...
Grudgee Every Mod's Favourite Member Member 1,496 Member For: 17y 1m 25d Gender: Male Location: Melbourne Posted 18/05/08 11:19 AM Share Posted 18/05/08 11:19 AM (edited) R-SPEC said: You need these things, plus a 90° metal pipe, a 3" silicone hose, a can of Coke and a smile.And the answer is yes, IF it's not more complicated than a sedan... Riddle me thatAlrighty then. I'll hold you to that. I'll take some pics of the engine bay so you can see if you reckon it'll be easy, or a bitch.In the meantime, I'll collect up the following checklist of goodies.- 1" rubber chair leg stopper thingy (now sure which kind of these to go for)- 90° 3" metal pipe,- 2 x 100mm lengths of 3" silicone hose- a can of Coke- smile (got this one already)- 2 x 3" hose clamps- pod filter (not sure what's best, but I assume the smallest, so it'll fit in a tight spot)- adapter for pod to 3" hose? <- just assuming I'll need one.With that all said, when's the next cruise? Edited 18/05/08 11:21 AM by Grudgee Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/2/#findComment-678389 Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 5m Gender: Male Location: Melbourne Posted 18/05/08 11:26 AM Share Posted 18/05/08 11:26 AM Don't buy everything yet. Just wait till I have a look at the engine bay.The next cruise is when you organise it! Link to comment https://www.fordxr6turbo.com/forum/topic/45630-how-to-block-off-bov/page/2/#findComment-678395 Share on other sites More sharing options...
