tab Sucker Moderating Team 32,303 Member For: 21y 1m 11d Gender: Male Location: Brisbane Posted 15/05/08 04:30 AM Share Posted 15/05/08 04:30 AM For the car to be able to drive while the alarm is active, it normally indicates that the alarm does not have a immobilizer function, but rather is only a 'siren' type alarm. If this is the case, might be worth looking at having a new alarm installed which actually has a immobilizer function also...The immobiliser function comes standard on all falcons, as soon as the coded key is put in the ignition it’s disabled. Link to comment https://www.fordxr6turbo.com/forum/topic/45515-alarm-goes-off-when-starting-car-sometimes/page/2/#findComment-676376 Share on other sites More sharing options...
Kimberley Scott www.australianflag.org.au Donating Members 6,763 Member For: 19y 10m 19d Gender: Male Location: Brisbane Posted 15/05/08 04:37 AM Share Posted 15/05/08 04:37 AM An edit and 16 PSI will fix this, just adda bigger IC, fuel pump, injectors, cat and some other bits and pieces to help keep the engine safe.Scotty Link to comment https://www.fordxr6turbo.com/forum/topic/45515-alarm-goes-off-when-starting-car-sometimes/page/2/#findComment-676381 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m 28d Gender: Male Location: SW Sydney Posted 15/05/08 04:40 AM Share Posted 15/05/08 04:40 AM The immobiliser function comes standard on all falcons, as soon as the coded key is put in the ignition it’s disabled.Correct Sir! well done! Link to comment https://www.fordxr6turbo.com/forum/topic/45515-alarm-goes-off-when-starting-car-sometimes/page/2/#findComment-676386 Share on other sites More sharing options...
smicky Go Pies!!! Donating Members 2,852 Member For: 17y 3m 19d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 15/05/08 06:46 AM Share Posted 15/05/08 06:46 AM The immobiliser function comes standard on all falcons, as soon as the coded key is put in the ignition it’s disabled.Correct Sir! well done! Yes - guys you are correct...They are stock.... have been since the EA (ford) I think???What I was referring to was if the alarm is engaged (going off) the alarm 'should' also prevent the car from starting/being drivable...I know that some alarms dont, and as the car is drivable while the alarm is going off, it obviously indicates that the alarm is not connected to the immobilizer... However what I was trying to say was that it is worth getting an alarm with immobilizer function also...Made the assumption that the alarm was a basic 'siren' alarm only in this case...Had a mates car with a basic alarm stolen as they bypassed the immobilizer somehow (I dont know details on this however that's all he said) - since I make it a point to get an alarm with one build in also... (extra 20$ on many upgrade alarms)...I have bypassed alarm immobilizer myself on the old Liby GT - however only as the alarm has a problem... But still worth the extra 'I Believe'.... Link to comment https://www.fordxr6turbo.com/forum/topic/45515-alarm-goes-off-when-starting-car-sometimes/page/2/#findComment-676479 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 1m 11d Gender: Male Location: Brisbane Posted 15/05/08 07:46 AM Share Posted 15/05/08 07:46 AM It is only a problem because the alarm is somehow faulty yes? If someone is going to go to the effort of disabling an immobiliser, I'm pretty sure they'd be disabling the alarm as well.....so it wouldn’t really achieve too much at all.Apologies if I'm not getting your point, but it makes no sense for my rather simple mind Link to comment https://www.fordxr6turbo.com/forum/topic/45515-alarm-goes-off-when-starting-car-sometimes/page/2/#findComment-676525 Share on other sites More sharing options...
cobrav8 Member 1,969 Member For: 20y 2m 12d Gender: Male Location: New Zealand Posted 15/05/08 08:45 AM Share Posted 15/05/08 08:45 AM I had an alarm on an EBXR8 that used to have the annoying feature of opening and shutting the door locks at random. This then extended to setting the alarm off, and it always seemed to be at one set of traffic lights on the 100 kph road.In the end what I found wrong was a poor earth for the siren unit to the body. Never had any of these issues again. Link to comment https://www.fordxr6turbo.com/forum/topic/45515-alarm-goes-off-when-starting-car-sometimes/page/2/#findComment-676569 Share on other sites More sharing options...
MICKAJ Member 245 Member For: 17y 3m 9d Posted 16/06/08 08:34 AM Share Posted 16/06/08 08:34 AM Stop stealing cars Link to comment https://www.fordxr6turbo.com/forum/topic/45515-alarm-goes-off-when-starting-car-sometimes/page/2/#findComment-693937 Share on other sites More sharing options...
Chich Damn You's A Sexy Chich Member 3,843 Member For: 17y 3m 20d Gender: Male Location: Your House Posted 16/06/08 08:38 AM Share Posted 16/06/08 08:38 AM Stop stealing cars try starting YOUR car Link to comment https://www.fordxr6turbo.com/forum/topic/45515-alarm-goes-off-when-starting-car-sometimes/page/2/#findComment-693943 Share on other sites More sharing options...
DesFlurane Member 351 Member For: 19y 1m 17d Gender: Male Posted 16/06/08 09:58 AM Share Posted 16/06/08 09:58 AM My alarm has started playing up BF F6.Checked the battery and sure enough only a quarter charged.Haven't checked if the trickle charger worked as I haven't connected up the siren again. Link to comment https://www.fordxr6turbo.com/forum/topic/45515-alarm-goes-off-when-starting-car-sometimes/page/2/#findComment-693994 Share on other sites More sharing options...
