hanra Into the laaaake Member 1,532 Member For: 17y 5m 17d Gender: Male Location: Nrth Qld Posted 14/05/08 09:31 AM Share Posted 14/05/08 09:31 AM A decent UBP wouldnt hurt either, there only like $120! Link to comment Share on other sites More sharing options...
groper Member 611 Member For: 17y 10m 1d Posted 14/05/08 12:11 PM Share Posted 14/05/08 12:11 PM Well said groper. But does the actuator spring give more power or just enable the car to make more power down low ? I thought that it just got rid of lag and made a sharper curve.it enables the tuner to control boost easier, therefore he will be able to push it further and extract more power from it without worry of loss of boost control.you will get a flatter boost curve without such a big spike in it. that allows the tuner to run higher boost up high without a rediculous boost spike down lower and more linear power delivery if you want it... Link to comment Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 18y 8m 11d Posted 14/05/08 12:15 PM Share Posted 14/05/08 12:15 PM Its all about the consistency as groper has stated. Link to comment Share on other sites More sharing options...
XR6 Turbo Developments Member 100 Member For: 16y 9m 15d Gender: Male Location: Dandenong Posted 14/05/08 02:33 PM Share Posted 14/05/08 02:33 PM it enables the tuner to control boost easier, therefore he will be able to push it further and extract more power from it without worry of loss of boost control.you will get a flatter boost curve without such a big spike in it. that allows the tuner to run higher boost up high without a rediculous boost spike down lower and more linear power delivery if you want it...You will also find that a larger actuator allows the turbo to spool quicker as well. It allows the wastegate flap to stay shut longer allowing boost to build faster.. We offer a wastegate and flapper modofocation at a very affordable price.Jim Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 16y 10m 14d Gender: Male Posted 15/05/08 09:26 AM Share Posted 15/05/08 09:26 AM Cheers guys. Link to comment Share on other sites More sharing options...
skunk Member 236 Member For: 17y 1m 6d Gender: Male Location: melb Posted 15/05/08 10:53 AM Share Posted 15/05/08 10:53 AM godamn valve springs ! oh and actuator too !!! NGggh!!! still need mine done Link to comment Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 2m 4d Gender: Male Posted 03/06/08 06:37 AM Share Posted 03/06/08 06:37 AM ok, im in a good mood and wont ask you to search the forum, but it goes like this;1. If its a manual, get a new clutch first, otherwise you will blow your tuning session.2. your valve springs are a maybe, if you really want 300+, change them otherwise you wont achive the potential of your other mods, and thus blow your tuning session.3. take injectors to install on the day of your tuning session, 968`s or siemans are fine at 300rwkw, go for whatever is cheaper, use the siemans if youll want 330+rwkw later.4. get a good intercooler if you have $1000 OR water/methanol injection for $500 if you wanna go a bit cheaper (band aid fix).5. punch the cat OR if you wanna stay legal, buy a good HI flow one and get it welded in, the rest of the exhaust is ok up to about 320rwkw.6. get a 12psi actuator installed (optional) but it will allow the tuner to control boost better and hell be able to give you a bit more power with it.the above will get you around 320rwkw. without the actuator ~ 300rwkw.hey guys just bumping his thread back up,, cbf making one which prob exists.. anyways,, with all mentioned above in the quote, what if it was an auto insted of a manual..? Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 6m 6d Gender: Male Location: Melbourne Posted 03/06/08 06:54 AM Share Posted 03/06/08 06:54 AM A good tuner will be able to firm up the shifts for ya, maybe a transcooler to 4 speed or 6 speed? Link to comment Share on other sites More sharing options...
Erko Donating Members 1,079 Member For: 21y 1m 29d Gender: Male Location: Sydney Posted 03/06/08 07:42 AM Share Posted 03/06/08 07:42 AM What I am running now :Plazmaman IC and UBPSiemens DekasX Force 3' catPW Surge and Bosch 044makes an easy 288rwkw, with the IC it will run all day without pressure drop and the Surge and Pump keep things safe - ie. wont lean out under heavy load. The 3' inlet X Force cat flows 700cfm which is plenty for the stock systems capability of 560cfm. next step up on this is to go with a 12psi actuator, and I will do this down the track. at the moment the power level is great.......especially on these wet sydney roads! Link to comment Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 5m 17d Gender: Male Location: Nrth Qld Posted 03/06/08 08:02 AM Share Posted 03/06/08 08:02 AM (edited) I just managed 296.1rwkw with a 4psd Auto, my mods are: Monsta I/CProcess West UBPRAPID Hot/Cold PipingSiemens Deka'sBosch 0442L Surge tankTyphoon CAIK&N Filter3.5in X-Force CatAtomic Valve Springs Edited 03/06/08 08:02 AM by hanra Link to comment Share on other sites More sharing options...
