RHR BOOST Moderating Team 5,698 Member For: 21y 5m 25d Gender: Male Location: Southern Highlands NSW Posted 16/05/10 09:10 AM Share Posted 16/05/10 09:10 AM the RTV was axed when the BF finished Link to comment Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 21y 10m 9d Gender: Male Location: stanthorpe wine capital of qld. Posted 16/05/10 09:15 AM Share Posted 16/05/10 09:15 AM if you are talking the rtv falcon ute it is not 4x4 drive it is just a riased up falcon ute with a hydro torque rear diff.Ian Link to comment Share on other sites More sharing options...
gsimon Member 28 Member For: 19y 7m 25d Gender: Male Location: Perth Posted 15/07/11 07:28 PM Share Posted 15/07/11 07:28 PM Main problem of fitting the Territory AWD to a Falcon would be the ride height, and the floor pan modification needed where the transfer case sits. The Territory looks like it sits approx 50 mm above a Falcon. I recon a complete front suspension off Territory would be needed, but with maximum lowering to bring it down to Falcon looks. This could affect the front driveshafts.Falcon and Territory obviously have the same frame rails, the same firewall, quite similar floor pan, but differences in the centre tunnel where the transfer case is located. Welding in a piece of Territory Floorpan into a Falcon would probably be possible. The front end frame rails are the same, only stud location is different, and these can be moved. I own a BA XR6 that it would be interesting to convert to AWD, as it is going to get a turbo conversion soon, however the ride height is my main consern. Wouldn't look good if it has to sit 50 mm. above standard falcon..hehe.. I also own a BA RTV Ute. As mentioned above a lot of people think these are 4x4, but as mentioned they all were only RWD with a diff lock. I recon the RTV would be very easy to convert to a Territory AWD front suspension, as the RTV already have the raised ride height needed. Only the floor pan job to do, move the front rail studs, and the rest should bolt in. Unfortunately, the value would hardly go up, and spending all that effort on a $10k vehicle is not really worth it. Link to comment Share on other sites More sharing options...
BBQBurner Member 5 Member For: 16y 10m 17d Posted 17/07/11 09:43 AM Share Posted 17/07/11 09:43 AM chassis rails are different, have a notch to clear front drive shafts. Link to comment Share on other sites More sharing options...
mygarfield Banned 23 Member For: 13y 7m 24d Gender: Male Posted 17/07/11 11:11 AM Share Posted 17/07/11 11:11 AM in the states, the cool thing to do is jack your car UP (not down like we do here). Maybe someone can bring it around down here. Link to comment Share on other sites More sharing options...
cobramad Member 824 Member For: 19y 7m 12d Gender: Male Location: Perth Posted 18/07/11 12:56 PM Share Posted 18/07/11 12:56 PM I had a close look at the front diff set-up and as it stands, there is about 25mm between the front driveshaft tube and the sump. Biggest obstacle is the angle at which the front driveshaft leaves the transfer box as this determines the position of the front diff in relation to the motor. If you could get the front diff right inside the sump, a la GTR Nissan, you're some way there to getting the package to sit under a Falcon floorpan. Huge engineering effort required, along with an equally sizeable helping of commitment to get this off the ground, but certainly not impossible. I have access to all the parts to make it happen, but damn, its still a monster project..Or you could wait for the AWD Taurus due in 2015 or so..Mal K Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 30d Gender: Male Location: Sydney Posted 18/07/11 11:23 PM Share Posted 18/07/11 11:23 PM taurus....just the thought sends a shiver down my spine Link to comment Share on other sites More sharing options...
cobramad Member 824 Member For: 19y 7m 12d Gender: Male Location: Perth Posted 19/07/11 12:56 PM Share Posted 19/07/11 12:56 PM Face the facts, for its going to eventually be the next Falcon.. and from all accounts will fill in nicely when out Territory Turbo gets too long in the tooth. Lots of room and a twin turbo V6 with lots of tuning potential. That or possibly an Audi Q7.. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 3m 6d Gender: Male Location: Probably above atmospheric pressure Posted 20/07/11 12:39 PM Share Posted 20/07/11 12:39 PM Mustang global RWD, save me! Link to comment Share on other sites More sharing options...
cobramad Member 824 Member For: 19y 7m 12d Gender: Male Location: Perth Posted 21/07/11 02:34 PM Share Posted 21/07/11 02:34 PM Sadly the Mustang platform isnt remotely as refined as FG.. it will come down to a global platform unfortunately.. Here in Oz we are just small fish from a global manufacturing perspective and the tiny volumes we build and consume are a drop in the ocean when compared to overall production numbers.. Crown Victoria anyone? Link to comment Share on other sites More sharing options...
