KryZak Member 91 Member For: 17y 10m 21d Gender: Male Location: Perth, WA Posted 05/05/08 02:05 AM Share Posted 05/05/08 02:05 AM Hi Guys,I did an oil change on my BF2 T on the weekend, but I think I may have put too much oil back in. Is there any adverse affects that this could cause. I filled the oil filter before installing, and put 5L into the sump. I estimated there would be 5.5L in the car now. I ran the car on the starter for ~30 seconds (pulled fuel pump relay) to get the oil circulating. The dipstick barely registered anything after this. I chucked in another litre, taking it to the 6.5L capacity. I cranked it on the starter again and then left the car for 10 minutes for the oil to run down to the sump. The dipstick registered halfway up the OK mark. I put about another 500ML in and it took it to the Full mark. Took the car for a run and checked it at home and it was still at Full. Checked it this morning after doing a 100km drive yesterday and it is now 4-5mm above the full mark on the dipstick! How would that happen, and will it be OK?Cheers,Michael Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 17d Gender: Male Location: SW Sydney Posted 05/05/08 02:13 AM Share Posted 05/05/08 02:13 AM the T takes 7.5L so you should be fine mate, if it's over full you will definately know about it, alot of smoke and a poorly performing engine is the result Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 5m 1d Gender: Male Location: Perth Posted 05/05/08 02:19 AM Share Posted 05/05/08 02:19 AM Too much oil can cause overheating, excessive crankcase breathing and in a turbo car, turbo seal issues as the increased crank case pressure can cause oil drain issuses in the turbo. If its a genuine 5mm over the full mark i would drain some oil out. cheersLuke Link to comment Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 8m 10d Gender: Male Location: Nrth Qld Posted 05/05/08 02:29 AM Share Posted 05/05/08 02:29 AM You dont have to go pulling relays out mate, just hold your foot flat on the accelerator pedal when you crank it. Link to comment Share on other sites More sharing options...
markxr6t Member 476 Member For: 20y 3m 25d Location: Perth WA Posted 05/05/08 02:32 AM Share Posted 05/05/08 02:32 AM My owners manual for my BF says 6.6 litres of oil to fill including new filter???? Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 17d Gender: Male Location: SW Sydney Posted 05/05/08 02:54 AM Share Posted 05/05/08 02:54 AM Apologies, but BA's take 7.5L, the BF has a smaller filter too Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 1m 6d Gender: Male Posted 05/05/08 02:54 AM Share Posted 05/05/08 02:54 AM My owners manual for my BF says 6.6 litres of oil to fill including new filter????Dont know why your manual would say that. Should be 7.5 inc filter. Are you reading the correct info ? Link to comment Share on other sites More sharing options...
tmac450 Member 1,650 Member For: 18y 5m 20d Gender: Male Location: NSW Posted 05/05/08 03:19 AM Share Posted 05/05/08 03:19 AM Don't worry, overfilling the oil was Holden's solution to the piston slap issues they had with their Gen III's. If it overheats, blows smoke, burns oil and fowls things, ' it's all within spec.' Link to comment Share on other sites More sharing options...
KryZak Member 91 Member For: 17y 10m 21d Gender: Male Location: Perth, WA Posted 05/05/08 04:14 AM Author Share Posted 05/05/08 04:14 AM (edited) Thanks guys. It isnt blowing smoke and seems to be performing OK (a little slow, but normal - I think that's my right foot itching for more power! ). I will keep an eye on it and if it stays high by the weekend, I may drain a little out.Oh, and hanra, I tried that - it doesnt work in my car. Foot flat to the floor, it still starts...?! Edited 05/05/08 04:17 AM by KryZak Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 9m 30d Gender: Male Location: Brisbane Posted 05/05/08 06:08 AM Share Posted 05/05/08 06:08 AM Apologies, but BA's take 7.5L, the BF has a smaller filter tooDry or wet fill? Link to comment Share on other sites More sharing options...
