neo Member 376 Member For: 17y 3m 25d Gender: Male Location: The Ville Posted 27/04/08 11:09 AM Share Posted 27/04/08 11:09 AM I think my plugs are going and I want to get new ones. was told the copper ones last less time but the performance one last longer but throw less spark is the true. what you guys using and can it be a DIY job. do I need a special plug remover also anything to watch out for.? Link to comment https://www.fordxr6turbo.com/forum/topic/44916-spark-plugs-whats-best/ Share on other sites More sharing options...
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 17y 10m 16d Gender: Male Location: Perff, WA Posted 27/04/08 11:36 AM Share Posted 27/04/08 11:36 AM neo, what makes you think they're 'going'?? what symptoms are there?they can be done pretty easily yourself, but yeh, what's wrong first??Dan Link to comment https://www.fordxr6turbo.com/forum/topic/44916-spark-plugs-whats-best/#findComment-666395 Share on other sites More sharing options...
neo Member 376 Member For: 17y 3m 25d Gender: Male Location: The Ville Posted 28/04/08 02:34 AM Author Share Posted 28/04/08 02:34 AM the car seams to be missing I have got a full service history on my car called the place that had done the services before I got my car but they never did the plugs and its up for a new service soon and I want to make shore it gets new plugs. Link to comment https://www.fordxr6turbo.com/forum/topic/44916-spark-plugs-whats-best/#findComment-666644 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 13d Gender: Male Location: Perth Posted 28/04/08 02:47 AM Share Posted 28/04/08 02:47 AM IIRC BRP6EIX? is the pregapped to .8mm plug? Ala Wrx. Link to comment https://www.fordxr6turbo.com/forum/topic/44916-spark-plugs-whats-best/#findComment-666649 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 29d Gender: Male Location: SW Sydney Posted 28/04/08 03:01 AM Share Posted 28/04/08 03:01 AM You can get specific F6 plugs from ford spares or auto stores, they are about $15 a pop but are better plugs and already have a 0.8-0.9 gap Link to comment https://www.fordxr6turbo.com/forum/topic/44916-spark-plugs-whats-best/#findComment-666656 Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 20y 13d Gender: Male Posted 28/04/08 05:59 AM Share Posted 28/04/08 05:59 AM IIRC BRP6EIX? is the pregapped to .8mm plug? Ala Wrx.BKR6EIX is the ticket. make sure you get the standard ones as they make a BKR6EIX1.1 with the bigger gap.how many km's you done neo? they are in the service book to be done at 90k I think. changed mine at around 70iirc when I got the edit.N0.6 can be a pain because its close to the firewall but I just used an elbow attachment on my socket and it was sweet. one of those flexi attachments you can get would be the best option I rekon! Link to comment https://www.fordxr6turbo.com/forum/topic/44916-spark-plugs-whats-best/#findComment-666752 Share on other sites More sharing options...
neo Member 376 Member For: 17y 3m 25d Gender: Male Location: The Ville Posted 28/04/08 12:20 PM Author Share Posted 28/04/08 12:20 PM car has done 11900 when I got it 2 months ago now has 123,000 odd. I am looking at doing the first 3 on here http://www.fordforums.com.au/showthread.php?t=73561intake Clean and Turbo sol clean and tighten the bolts. also at the same time thinking of doing the spark plugs. as the intake will be off. what im not shore about the gap I should have on NGK website for Ba XR6T Recommended Plug FR6EI-11 1.1 and I cant find it on the STANDARD TO IRIDIUM - IX CONVERTER. but do you guys recommend a smaller gap 0.8 if so why a smaller gap. just thinking about it please tell me if im wrongI would think that smaller gap less distance for the spark to travel so giving stronger spark. but do they burn out quicker is there a down side to this Gap? would you guys also replace the coils or just forget them. with the removal of the plugs I just use the allen keys to get the cover off and then use a standard spark plug remover is the spark plug hole deep will I need and extension on the spark plug socket? I just want to do this right the first time that's all cheers Link to comment https://www.fordxr6turbo.com/forum/topic/44916-spark-plugs-whats-best/#findComment-667079 Share on other sites More sharing options...
Phoontastic Donating Members 262 Member For: 19y 5m 3d Gender: Male Location: Canberra Posted 28/04/08 12:54 PM Share Posted 28/04/08 12:54 PM If your car is stock then you probably want to use the stock plug gap, which I think is 1.1mm. If you've had it edited then you probably want to go to the 0.8mm (or slightly less). I believe this is because higher boost levels can make it harder for the spark to travel between the electrodes at higher revs. The Ford gas plugs are fine, and come already gapped to suit an edited car. Changing the plugs is straight forward, but you will need an extension on the plug socket. I use a socket that positively captures the plug so it doesn't drop from the socket when you're doing it. I'd forget about the coils too. They're expensive, particularly if you want to buy 6 of them, and you'll soon know if one is stuffed. Link to comment https://www.fordxr6turbo.com/forum/topic/44916-spark-plugs-whats-best/#findComment-667095 Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 10m 18d Gender: Male Location: Broady, Melbourne Posted 28/04/08 01:13 PM Share Posted 28/04/08 01:13 PM I had some missing at hard throttle and general roughness recently. Although my plugs didn't look stuffed, they were. I went for one cooler and got the NGK bkr7eix. They seem to be working very nicely.You will need the smaller gap if you are running higher boost as it will blow the spark out. Change the plugs first to see if that fixes your issues then go from there. Depending on how much boost you run and how often you're into it, Iridium plugs may only last 20,000kms. You will need an extension and no 6 is a bit of a bother. Link to comment https://www.fordxr6turbo.com/forum/topic/44916-spark-plugs-whats-best/#findComment-667104 Share on other sites More sharing options...
neo Member 376 Member For: 17y 3m 25d Gender: Male Location: The Ville Posted 29/04/08 09:34 AM Author Share Posted 29/04/08 09:34 AM they you very much guys for all your help and info. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/44916-spark-plugs-whats-best/#findComment-667531 Share on other sites More sharing options...
