  • Forged Member
  • Member For: 18y 4m 4d
I'm guessing you mean "B"F rather than EF, but it can be a problem, your car is under warranty, so get the ford guys to fix it - is it leaking alot?
  • Member For: 17y 2m 3d
yep...BF (its been a long day!!) :stupid:
It's leaking a fair bit, particularly after a long stint. I suspect the o-ring to the high pressure pipe has :thumbsup: itself.
Have organised the ford dealer to check it monday...just interested to see if this is common or otherwise.
Bit concerned that the heated fluid is dropping onto the alternator directly below.
Cheers senna_T
  • Forged Member
the alternator should be fine, I've seen plenty of alternators swimming in fluid and they turn out just fine strangely enough!
No Worries mate :thumbsup:
  • Moar Powar Babeh
  • Member For: 19y 8m 19d
If your high pressure pipe is leaking fraud willl try and sell you the entire pipe and hose assembly ($400+) if you can't squeeze it through under waranty, your local pirtek/enzed hose dude should have the nouce to replace the fitting with out replacing the hose. If your mech minded you can do it yourself with a junior hacksaw and a dremel with a cut off wheel. You need to cut the old fitting off (without knicking the pipe) and the new fitting with the new oring clips onto the pipe. obviously you'l need to flush the pipe so you dont get any metal contamination in the steering system. You can get the fittings for around $40 from coventries or your local equvilent.
Luke :spoton:
  • My engine bay is Bionic
  • Member For: 19y 2m 23d
How bloody typical! $400 from Fraud and $40 from someone else.
I.B.
  • Member For: 17y 11m 19d
When mine was leaking slightly from the lower pipe (above the alternator) it jsut required a retension. 1/4 turn of the wrench and it hasnt begun leaking again in over 5 months.
give this a try first, but go easy, just gently nip it up.
  • Member For: 18y 4m 19d
  srxr6t said:
thanks for the info lads...the dealer has agreed it's warranty work, so we'll see how they go...the mechs are pretty vague though??
Did they look at it or did you just speak to them? If you only spoke to them they'd be pretty loathe to speculate at that point. My guess is the high pressure hose is leaking. Mine went twice under warrantly on the BA and the last one that went was out of warranty. I replaced it with a reco'd enzed unit. A year later and no dramas from the hose, but now the pump is actually leaking so I'll need to replace that.
