srxr6t Member 14 Member For: 16y 10m 22d Location: Fremantle - WA Posted 19/04/08 11:58 AM Share Posted 19/04/08 11:58 AM Has anyone experienced leaking power steering pumps in the EF XR6T? Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 23d Gender: Male Location: SW Sydney Posted 19/04/08 12:05 PM Share Posted 19/04/08 12:05 PM I'm guessing you mean "B"F rather than EF, but it can be a problem, your car is under warranty, so get the ford guys to fix it - is it leaking alot? Link to comment Share on other sites More sharing options...
srxr6t Member 14 Member For: 16y 10m 22d Location: Fremantle - WA Posted 19/04/08 12:16 PM Author Share Posted 19/04/08 12:16 PM yep...BF (its been a long day!!) It's leaking a fair bit, particularly after a long stint. I suspect the o-ring to the high pressure pipe has itself.Have organised the ford dealer to check it monday...just interested to see if this is common or otherwise.Bit concerned that the heated fluid is dropping onto the alternator directly below.Cheers senna_T Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 23d Gender: Male Location: SW Sydney Posted 19/04/08 12:24 PM Share Posted 19/04/08 12:24 PM the alternator should be fine, I've seen plenty of alternators swimming in fluid and they turn out just fine strangely enough! No Worries mate Link to comment Share on other sites More sharing options...
srxr6t Member 14 Member For: 16y 10m 22d Location: Fremantle - WA Posted 19/04/08 12:32 PM Author Share Posted 19/04/08 12:32 PM sweet mate...have a good one! Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 7d Gender: Male Location: Perth Posted 20/04/08 12:58 AM Share Posted 20/04/08 12:58 AM If your high pressure pipe is leaking fraud willl try and sell you the entire pipe and hose assembly ($400+) if you can't squeeze it through under waranty, your local pirtek/enzed hose dude should have the nouce to replace the fitting with out replacing the hose. If your mech minded you can do it yourself with a junior hacksaw and a dremel with a cut off wheel. You need to cut the old fitting off (without knicking the pipe) and the new fitting with the new oring clips onto the pipe. obviously you'l need to flush the pipe so you dont get any metal contamination in the steering system. You can get the fittings for around $40 from coventries or your local equvilent.Luke Link to comment Share on other sites More sharing options...
Iconic Bionic My engine bay is Bionic Donating Members 3,726 Member For: 18y 11m 11d Gender: Male Location: Freeways Posted 20/04/08 08:29 AM Share Posted 20/04/08 08:29 AM How bloody typical! $400 from Fraud and $40 from someone else.I.B. Link to comment Share on other sites More sharing options...
Full Monty Member 513 Member For: 17y 8m 7d Gender: Male Location: Melbourne Posted 20/04/08 09:33 AM Share Posted 20/04/08 09:33 AM When mine was leaking slightly from the lower pipe (above the alternator) it jsut required a retension. 1/4 turn of the wrench and it hasnt begun leaking again in over 5 months.give this a try first, but go easy, just gently nip it up. Link to comment Share on other sites More sharing options...
srxr6t Member 14 Member For: 16y 10m 22d Location: Fremantle - WA Posted 21/04/08 01:14 AM Author Share Posted 21/04/08 01:14 AM thanks for the info lads...the dealer has agreed it's warranty work, so we'll see how they go...the mechs are pretty vague though?? Link to comment Share on other sites More sharing options...
The Unforgiven Member 119 Member For: 18y 1m 8d Gender: Male Location: Adelaide Posted 21/04/08 10:53 PM Share Posted 21/04/08 10:53 PM thanks for the info lads...the dealer has agreed it's warranty work, so we'll see how they go...the mechs are pretty vague though??Did they look at it or did you just speak to them? If you only spoke to them they'd be pretty loathe to speculate at that point. My guess is the high pressure hose is leaking. Mine went twice under warrantly on the BA and the last one that went was out of warranty. I replaced it with a reco'd enzed unit. A year later and no dramas from the hose, but now the pump is actually leaking so I'll need to replace that. Link to comment Share on other sites More sharing options...
