AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 18y 2m 14d Gender: Male Location: Canning Vale, W.A Posted 19/04/08 07:14 AM Share Posted 19/04/08 07:14 AM Any give me some quick tips on how to fit it up? lolI'm having a mind blank at the moment and I cant for the life of me remember..By the way this is on a process west stage 2 with the CAI and the replacement crossover.If anyone has done this already could ya give me a hand? thanks Link to comment https://www.fordxr6turbo.com/forum/topic/44641-so-i-bought-a-bov/ Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 18y 2m 14d Gender: Male Location: Canning Vale, W.A Posted 19/04/08 07:17 AM Author Share Posted 19/04/08 07:17 AM Oh I want to make it vented and its a Turbosmart Dual port.. Link to comment https://www.fordxr6turbo.com/forum/topic/44641-so-i-bought-a-bov/#findComment-661666 Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 18y 2m 14d Gender: Male Location: Canning Vale, W.A Posted 19/04/08 07:56 AM Author Share Posted 19/04/08 07:56 AM OP! Link to comment https://www.fordxr6turbo.com/forum/topic/44641-so-i-bought-a-bov/#findComment-661674 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 19d Gender: Male Location: Perth Posted 19/04/08 08:06 AM Share Posted 19/04/08 08:06 AM Got any photos of you eng bay? I may shed some light on the subject. Do you have a bov installed at the mo? Link to comment https://www.fordxr6turbo.com/forum/topic/44641-so-i-bought-a-bov/#findComment-661677 Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 18y 2m 14d Gender: Male Location: Canning Vale, W.A Posted 19/04/08 08:48 AM Author Share Posted 19/04/08 08:48 AM ??????????????????????! Link to comment https://www.fordxr6turbo.com/forum/topic/44641-so-i-bought-a-bov/#findComment-661692 Share on other sites More sharing options...
ETM Member 1,194 Member For: 18y 2m 29d Gender: Male Location: syd south Posted 19/04/08 08:51 AM Share Posted 19/04/08 08:51 AM you need to weld a bov attachment pipe onto the crossover pipe,that pipe looks powdercoated,not good lol.other than that the bov only needs a single signal from the inlet behind the throttle to operate Link to comment https://www.fordxr6turbo.com/forum/topic/44641-so-i-bought-a-bov/#findComment-661693 Share on other sites More sharing options...
ETM Member 1,194 Member For: 18y 2m 29d Gender: Male Location: syd south Posted 19/04/08 08:53 AM Share Posted 19/04/08 08:53 AM ok im a knob, you have the bov attachment pipe, you need a rubber hose to connect the bov to the pipe,its not the ideal setup but your pipe is setup for the stock bov,not an aftermarket one Link to comment https://www.fordxr6turbo.com/forum/topic/44641-so-i-bought-a-bov/#findComment-661694 Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 6m 28d Gender: Male Location: Dé·jà vu Posted 19/04/08 09:13 AM Share Posted 19/04/08 09:13 AM Probably be better to go to an engineering shop and get them to turn up an adaptor with which would fit between the two.....I could make one for you in about 1/2 an our but your a little to far away..... Link to comment https://www.fordxr6turbo.com/forum/topic/44641-so-i-bought-a-bov/#findComment-661697 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 22d Gender: Male Location: Sydney NSW Posted 19/04/08 12:26 PM Share Posted 19/04/08 12:26 PM Take the cast cross over section to a garage/fab shop that can TIG weld and get them to fit a 36mm to it... very easy job, cut the 25mm outlet off, open the hole up, and weld on the correct size fitting, which looks like the usual 36mm fitting.You can even buy the fitting from Turbosmart and have it welded on.Or, take the bov back and swap it for one with a 25mm inlet. Link to comment https://www.fordxr6turbo.com/forum/topic/44641-so-i-bought-a-bov/#findComment-661755 Share on other sites More sharing options...
Guest Guests Posted 19/04/08 06:24 PM Share Posted 19/04/08 06:24 PM So you did end up getting it! Just wait til you get the plenum and fit it up then Link to comment https://www.fordxr6turbo.com/forum/topic/44641-so-i-bought-a-bov/#findComment-661815 Share on other sites More sharing options...
