dms_dan Member 29 Member For: 17y 17d Posted 23/04/08 10:46 PM Author Share Posted 23/04/08 10:46 PM Yeah do that you will be impressed I think.I used to use Auto magic #49 but I now make my own special blend Link to comment https://www.fordxr6turbo.com/forum/topic/44596-wax-vs-polish/page/4/#findComment-664440 Share on other sites More sharing options...
Dream Machines Member 54 Member For: 18y 10m 14d Posted 12/05/08 05:55 AM Share Posted 12/05/08 05:55 AM (edited) Yeah do that you will be impressed I think.I used to use Auto magic #49 but I now make my own special blendWell done Mr DMS, some excellent education there, this is what is needed for all carlovers to get the best resultsThe most important part of detailing or just typical car care is techniqueUse any product and get the technique wrong and the results won't comeSure that's not so hard by hand but when a machine comes out of the cabinet, that's when it can get trickyAs for clay bars - clay magic blue and red are the best for picking up the most contamination but anyone using the red bar will need to polish the paint with menzerna Final or Intensive polish or similar slight abrasive to remove the marring that will be causedSonus have an ultra fine bar and their grey coloured fine/medium grade barThe ultra fine is perfect for regular use as it will not remove sealants or good waxesWhile I hate the CM blue's stiffness and have to put it in a microwave for 10 seconds to resoften it, it does a great job at picking up all that rubbish that we do not seeNow to PolishingYou really nailed it perfectly Dan with the difference between chemical and abrasive polishesThe Polylack/Carlack/Werkstatt acrylic systems give a plasticky look but are superb on metallic paints as the light is allowed to pass through better and no flake will be mutedI put five coats of werkstatt Acrylic Jett on my AU XR6 a few years ago and the flake came alive after that and the refractive index of the paint was raised and there was no more bowing or bending of the reflections, every reflection was dead level and straightIf there is some oxidation on your car's finish, the best way to start is with a chemical polishIt will chemically remove it all or most of it and then make the abrasive polishing work betterThe golden rule I believe is to seal or wax the paint once all preparation and polishing is completed, if this is not done, all your good work will wash away over time or be killed off by our Aussie UV raysChemical cleaners/polish that I like to use are those mentioned by Dan and theseFour Star UPCToughseal step 1Glare Zero & Micro FinishWerkstatt Prime AcrylicPoorboys Pro PolishKlasse AIO Permagard Slightly & SeverelyWork out what you really want out of your paint and then use products to achieve thisFor example - for an awesome slick feel, do not use acrylic sealants like werkstatt or Klasse, they will be smooth or slight slick but not as much as Zaino, Glare, Permagard, meguiars, AutoglymFor depth on solid paints (no metallic), two to four coats of a super polymer sealant (megs 21, NXT, Permagard, Glare etc) topped a few days or a week later with the same amount of natural carnauba wax will create thatOh and the amount of abrasive polishing that is done over the years on one car will effect the clearcoat clarity and thus the depth of the paintThis is why I no longer use Menzerna on my 10 year old paint, I want to keep as much clarity as possible and build on what is leftSo Glare and Permagard are on it now (side by side) and some of the orange peel (heavy on the doors) is being buried by their protective coatings (need a rotary polisher to do that)The last car I worked on, I used this combo (severe damage)Toughseal step 1 Prepsol (to remove toughseals residue)Hi Temp Extreme Cut plus w/ edge yellow woolMenzerna PO85RD 3.01 Intensive w/ lc Orange foamMenzerna 106FF w/ LC white foamMenzerna PO85RD Finishing polish w/ LC black & blue foamIPA wipedown to remove oils from menzernaBase coat of Permagard Slightly Sealed with Permagard Reactive Polymer.There is a real science to detailing, thus why there are only so few true professionals around like Dan. Absolutely artists Edited 12/05/08 06:05 AM by Dream Machines Link to comment https://www.fordxr6turbo.com/forum/topic/44596-wax-vs-polish/page/4/#findComment-674742 Share on other sites More sharing options...
cobrav8 Member 1,969 Member For: 20y 1m 10d Gender: Male Location: New Zealand Posted 12/05/08 08:04 AM Share Posted 12/05/08 08:04 AM I use more conventional stuff - and have a fantastic finish on my car.Rinse the car heavily - keeping very wet.I then use normal Mothers new car wash to wash the car with a synthetic sponge, kept clean and wet a lot. Rinsing down after a panel or two, then keep the next couple of panels wet. Keep the roof etc wet the whole way through.Then when the car is washed, I drive down the road at great speed to dry it quickly.When the car is fully dry, I use some "Kem-o-pro" liquid Carnuaba wax/auto polish (bought at a local body shop supply place), and apply it with a clean ripped up t-shirt. Polish two or three panels (in the shade) and then use a clean bit of shirt to polish off.It may not sound as trendy as these other things, but I can tell you there are no swirls, no scratches, and my car stays clean for a long time and it has a great shine. Link to comment https://www.fordxr6turbo.com/forum/topic/44596-wax-vs-polish/page/4/#findComment-674804 Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 5m 25d Gender: Male Location: Perth, NOR Posted 12/05/08 08:18 AM Share Posted 12/05/08 08:18 AM I used to drive up and down the street a few times to get most of the water off, but I stopped when I got the xr6t cos im worried about sand getting flicked up onto the car and this causing scratches as I dry it.What I do now, is to use the water sheeding (spelling?) technique where you get the hose and let it run off the car, it will almost leave the panels dry (if the cars already waxed/polished anyway) and then drive it straight inside and dry using my waffle weave towel. Once its all dry then I take it around the block and then dry off any runs once I get back into the garage. Link to comment https://www.fordxr6turbo.com/forum/topic/44596-wax-vs-polish/page/4/#findComment-674812 Share on other sites More sharing options...
cobrav8 Member 1,969 Member For: 20y 1m 10d Gender: Male Location: New Zealand Posted 12/05/08 09:12 AM Share Posted 12/05/08 09:12 AM Just go faster - I have never had issues with sand (though I dont live near the beach or sandy area). Link to comment https://www.fordxr6turbo.com/forum/topic/44596-wax-vs-polish/page/4/#findComment-674846 Share on other sites More sharing options...
dms_dan Member 29 Member For: 17y 17d Posted 12/05/08 09:36 AM Author Share Posted 12/05/08 09:36 AM Just go faster - I have never had issues with sand (though I dont live near the beach or sandy area).Ok I dont believe you!! You may not have any swirls as the wax could be loaded with fillers. Wipe the panel with alcohol then post up a shot in the sun and I bet you will!!Also when you drive a wet car down the road you will pick up bits of dirt, then when you wipe it you will cause swirling. Its that simple Link to comment https://www.fordxr6turbo.com/forum/topic/44596-wax-vs-polish/page/4/#findComment-674861 Share on other sites More sharing options...
cobrav8 Member 1,969 Member For: 20y 1m 10d Gender: Male Location: New Zealand Posted 12/05/08 09:50 AM Share Posted 12/05/08 09:50 AM Sounds like a good reason not to wipe the car down with alcohol then! Link to comment https://www.fordxr6turbo.com/forum/topic/44596-wax-vs-polish/page/4/#findComment-674869 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 2m 26d Gender: Male Location: SW Sydney Posted 12/05/08 09:52 AM Share Posted 12/05/08 09:52 AM that's like the old "its not illegal if I don't see it!" Link to comment https://www.fordxr6turbo.com/forum/topic/44596-wax-vs-polish/page/4/#findComment-674870 Share on other sites More sharing options...
dms_dan Member 29 Member For: 17y 17d Posted 12/05/08 10:06 AM Author Share Posted 12/05/08 10:06 AM lol yeah can work on the "if its not there I dont see it" principal lol Link to comment https://www.fordxr6turbo.com/forum/topic/44596-wax-vs-polish/page/4/#findComment-674879 Share on other sites More sharing options...
davidg2152 Donating Members 98 Member For: 18y 5m 18d Posted 07/07/08 11:29 PM Share Posted 07/07/08 11:29 PM My car is 9 month old silver XR6 T BF MKII.Polished bonnet with gold class when I picked it up and did nothing, used heaps. Paint feels grainy and rough however still looks new.Can someone suggest what products I should buy, and order I should put on car to get baby bum feel back.Car is outside day, garage night.CheersDave Link to comment https://www.fordxr6turbo.com/forum/topic/44596-wax-vs-polish/page/4/#findComment-702942 Share on other sites More sharing options...
