  • Member For: 20y 2m 23d
  straughsberry said:
You can get them with, or fit thermostats to protect against that occurring yes?
I have a housing for a 2 litre Escort motor (never used) that is a sandwhich plate idea - goes in place of oil filter, and has a thermostat built in - when open - circulates through cooler and filter, when closed just goes through filter only.
I think... that the Falcon uses the same filter, so should fit. So.... I plan on using this and a cooler. However, not sure where the cooler will fit.
  • Member For: 17y 11m 23d
Yes the typhoon and R-spec have an oil cooler, but it is plumbed into the coolant and relies on the water coolant to cool the oil, which is inherently ineficient as it transfers the oil temp into the coolant, which is also marginal under extreme conditions.
Edited by Full Monty
  • Member For: 19y 4m 9d
  hypnodoc said:
Yeah I know I have one, but being from FMC beancounters budget it will be the cheapest, only just enough to support 270 kw getting stick occasionaly, chinese POS they could find. I want a real one :tonguepoke: You are right Senna_T Kev is designing one, but my patience goes faster then his design and production and I saw some at a speed shop here in WA WA land today and though Hmmmmmmmmmmm
Here you go mate check this THREAD out... I have fitted a cooler to mine and cant recommend it highly enough.
Pete
