  • It's All In Your Mind
  • Member For: 21y 6m 5d
I'm thinking of putting an engine oil cooler on the R Spec, has anybody done this? Where do you mount them?, and how difficult is it? Thanks in advance
https://www.fordxr6turbo.com/forum/topic/44478-engine-oil-cooler/
  • Forged Member
  • Member For: 18y 2m 27d
LOL!
I'm pretty sure Kev from PW is developing a bigger one to fit in with the rest of his gear Doc
Edited by senna_T
Yeah I know I have one, but being from FMC beancounters budget it will be the cheapest, only just enough to support 270 kw getting stick occasionaly, chinese POS they could find. I want a real one :roflmbo: You are right Senna_T Kev is designing one, but my patience goes faster then his design and production and I saw some at a speed shop here in WA WA land today and though Hmmmmmmmmmmm
  • Moar Powar Babeh
  • Member For: 19y 7m 11d
Would be an easy fit Doc, if i was to fit a larger oil to air cooler i would disconnect the factory cooler and plumb the cooler into the original lines. I would be inclined to fit an engine oil temp gauge cause you REALLY dont want to over cool your engine oil... :shocked:
  • Forged Member
:brightidea: I can relate to the patience thing doc, I'm waiting for Kev's cooler to come out because I have a BA XR, not fitted with the factory cooler and plumbing
  • Member For: 17y 8m 16d
Would be an easy fit Doc, if I was to fit a larger oil to air cooler I would disconnect the factory cooler and plumb the cooler into the original lines. I would be inclined to fit an engine oil temp gauge cause you REALLY dont want to over cool your engine oil... :nyaah:
You can get them with, or fit thermostats to protect against that occurring yes?
  • Dropping a turd
  • Member For: 17y 6m 7d
I intend to fit one when Kev releases it. I will put a electric solenoid into the line so it will only open when the oil passes a certain temperature. Arron
