The Off Topic Thread.
KEN 24T
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 10m 17d
46 minutes ago, JETURBO said:
What lucky Member has got this massive beast !
this one?
https://www.aeroflowperformance.com/af8005-4005-boosted-7677-1-15-t4-twinentry
BOOSTED 7675 1.15 Turbocharger Specifications
Recommended horsepower rating: 475-1450HP
Recommended engine displacement: 2L to 8L
  • Dual ceramic ball bearing
  • Billet aluminium compressor wheel
  • Ported shroud compressor housing cover
  • Speed sensor port included in compressor cover (sold separately, AF8050-1010)
  • Recommended turbo drain adapter AF463-02 or AF463-06
  • M18x1.5mm coolant fittings sold separately
  • External wastegate sold separately
  • Turbine inlet gasket sold separately AF9557-0003
  • Turbine inlet & outlet flange V-band sold separately
  • Turbo oil feed plate sold separately AF463-01
Compressor
Inducer: 76mm
Exducer: 102mm
Extended Tip: 107mm
A/R: 0.60
Turbine
Inducer: 82mm
Exducer: 75mm
A/R: 1.15
Compressor Inlet: 5" Slip fit
Compressor Outlet: 4" V-Band (AF8080-1009)
Turbine Inlet Flange: T4 Twin Entry
Turbine Outlet Flange: 4" V-Band (AF8080-1001)
Wastegate: External wastegate
