The Off Topic Thread.
KEN 24T
  • MattyP
  • Cruise Control
  • Member For: 12y 9m 22d
Morning
last day of 12 straight
feels good
does anyone one know the normal size of the port on our housing and what it usually gets ported out to?
  • Member For: 15y 4m 11d
This might be a stupid question but can you put the fuel filter in back to front?
I have had rough idle since a little bit after having the filter changed by Auto Masters. I cleaned the throttle body, then at the last service MT found a faulty spark plug & changed it. That didn't solve the problem, so they thought it might be injector related.
As they are always busy, too save some time I took it to a place that took them out, ultrasonically cleaned them & the fuel rail & flow tested them. They came up 100%.
The guy went above & beyond for service, he also took the fuel filter off & swapped it around, which is when he noticed a huge improvement & I have too, even with throttle response.
  • Puff
  • Member For: 10y 28d
If the filter was flipped then I would suggest not driving it or starting it until a new filter is fitted.
A flipped filter will just dump its guts into your injectors.
  • skids
  • Member For: 12y 1m 29d
  • Gender: Not Telling
If you've gone through two fuel filters then I tend to think you've had a batch of dodgy fuel.
if you have more problems, it might pay to check the in tank filter sock thingy.
