Puffwagon Puff Gold Donating Members 16,181 Member For: 10y 1m 10d Gender: Male Location: South Australia Posted 07/02/24 02:46 AM Share Posted 07/02/24 02:46 AM @Slowxr6t look up what dynomite performance do with their modified manifolds. Rajab also make a factory style T4 manifold. To answer the question, it is unlikely to see any meaningful difference if there is a divider or not. Link to comment Share on other sites More sharing options...
Slowxr6t Member 569 Member For: 6y 3m 7d Location: New zealand Posted 07/02/24 03:51 AM Share Posted 07/02/24 03:51 AM @Puffwagon thanks for that info, really I thought it would have to help having a divider. I think I will go ahead with this project just to see if it can be done and if it gives any gain over my stock manifold and gtx gen 2 setup, I will keep gtx setup unmolested so I can bolt it back on if efr setup is too difficult or turns out a cluster, I will still be able to sell the efr. Efr is supposed to spool fast and having a 91mm exducer comp wheel should make gtx power at lower boost too. Gonna be some more custom fab work coming up for me. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,181 Member For: 10y 1m 10d Gender: Male Location: South Australia Posted 07/02/24 04:48 AM Share Posted 07/02/24 04:48 AM There might be a couple hundred rpm difference, that's less than what a hot or cold day will change, hence not meaningful. It's something but not much. Link to comment Share on other sites More sharing options...
Slowxr6t Member 569 Member For: 6y 3m 7d Location: New zealand Posted 07/02/24 07:48 AM Share Posted 07/02/24 07:48 AM @Puffwagon went to tuner today he check ecu and found higher intake air temps were making it go into limp and boost low, the ecu must close the throttle body down alot, very clever. So he changed that and im back to a peak of 19psi and it goes hard. Gave it a good thrash and it was good. It did start doing a slight rev oscillation on cruise but then came right itself. I thought it might have been the boost sensor saying enough when it hit 19psi. I will turn boost tap down a quarter turn to about 18psi. He couldnt find where or what to do to raise boost sensor voltage. Have you watched ONBOOST videos? Hes made 663rwkw on 35 frame turbo at 26psi and stock internals and stock zf. Amazing. That guy made the comment hes never come across boost sensor issue. Is newer fgx ecu different to earlier ecus?? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,181 Member For: 10y 1m 10d Gender: Male Location: South Australia Posted 07/02/24 10:57 AM Share Posted 07/02/24 10:57 AM Hub dyno is like tits on a fat chick, it doesn't count. Changing the boost sensor voltage might fix it, might not. Chuck a multimeter into the boost sensor and read what it says on full boost, you'll soon know if it's going out of range. Change the high fail parameter Link to comment Share on other sites More sharing options...
Slowxr6t Member 569 Member For: 6y 3m 7d Location: New zealand Posted 07/02/24 04:29 PM Share Posted 07/02/24 04:29 PM Thanks mate Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,301 Member For: 16y 11m 1d Gender: Male Location: Melbourne Posted 07/02/24 09:32 PM Share Posted 07/02/24 09:32 PM morning all, happy Thursday 📱 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,301 Member For: 16y 11m 1d Gender: Male Location: Melbourne Posted 08/02/24 09:36 PM Share Posted 08/02/24 09:36 PM morning all, happy Friday 📲 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,301 Member For: 16y 11m 1d Gender: Male Location: Melbourne Posted 09/02/24 09:42 PM Share Posted 09/02/24 09:42 PM morning all, happy Saturday ☎️ Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,301 Member For: 16y 11m 1d Gender: Male Location: Melbourne Posted 10/02/24 09:57 PM Share Posted 10/02/24 09:57 PM morning all, happy Sunday 📞 another hot and clear day so heading to the beach 😄 Link to comment Share on other sites More sharing options...
