  • Member For: 11y 1m 15d
  On 23/02/2023 at 10:46 PM, Puffwagon said:
It's not something available for the general public and you can't even do the course for it unless you're already a qualified mechanic.
Expand
Not entirely true - check out Hychill Hychill a/c gas
No doubt I'll be flamed by the "it's dangerous, your car will explode" haters, but it works, and anyone can buy it.
  • Member For: 10y 3m 23d
  • Gender: Not Telling
Yeah I've seen those, they only add gas, they don't draw a vacuum and dry out the system for the 45 minutes needed to check for leaks, remove old oil and properly prepare a system for new gas. They also can't change the oil in the system which is also necessary for a proper aircon service.
There is much more to a "regas" than just topping it off. Companies rely on users not knowing the correct procedure, hence the availability of these products.
That said, sometimes you can half ass sh*t and it'll work out fine, this is one of those things...and no, your car won't blow up lol 😆
No it isn't. Take an informed risk by all means, an uninformed risk taken upon the advice of people standing to have financial gain from your ignorance is unethical and immoral on the part of the sellers.
Edited by Puffwagon
My butt
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 13d
can't say I even understand the risk, so I won't take it... but others might :idunno:
Yerp. No real physical risk there if you're half way switched on. More than likely will make your aircon cooler too. Should still do it correctly though.
Far out man, how good are interest rate rises? Farken they could at least send out a bottle of lube with the monthly statement.
  • Sad 1
