Xr6t How To Reduce Lag?
hulk xr6t
  • Moar Powar Babeh
  • Member For: 19y 3m 3d
4.11's will make the car feell "laggy" Compared to stock gears as you are taking load off the motor so you dont build boost as quckly. the upside is even with less boost the 4.11's will get the car moving quicker than the stock gears on boost. Th 2800rpm convertor wont be doing you any favours off boost.
My 6 speed manual ute has 4.1's in it and in 1st and 2nd get around 6 pound at around 2800rpm. In 3rd and 4th i see 8 to 10 pound around 2500 rpm. Once it gets past six pound it boosts up to 15psi in the blink of an eye.
if you want to get rid of the lag fit a hot side pipe kit, nizpro/process west/rapid pleum and pipe kit.
that'l fix it :spoton:
Luke
  • Replies 30
  • Moar Powar Babeh
as a comparison to that ^, my car is getting 10-12psi at 2800 rpm - T56 with stock diff gears
In which gear Senna? The biggest problem with the 4.11's is maintaing traction in 1st and 2nd. Obviously wheel spin = less traction = less load = less boost.
The marangoni's mytho's are really good at maintaning traction in second but i havent got around to looking at what boost its making at what rpm in second since fitting them
EDIT:forgot to mention my car is tuned to come on pretty conservativly due to my smallish injectors and fuel pump. I could probably get more boost in lower if i did fit a surge tank and bigger squirts :spoton:
Edited by hiddeous
  • Member For: 18y 9m 2d
iv noticed the p800 kit with added hot side and cai spools up much quicker and sounds like a 747 taking off.
I had a guy in a vl ask me what mofo turbo I have in that.
  • Member For: 17y 3m 16d
To what extent can a tuner choose(Adjust) when boost comes on? Obsivouly it depends on mods, but lets say on a stock car with a simple custom tune. Can it be brought on at 3000rpm or 4000rpm by simply changing a few things around in the tune?
  • Forged Member
  • Member For: 17y 10m 19d
it can, but it will depend on how strong your wastegate actuator is, the stock one can't control boost too well when you get up in power and boost levels
