Fry Member 123 Member For: 18y 7d Gender: Male Location: S/E Melb Posted 01/04/08 07:34 AM Share Posted 01/04/08 07:34 AM just got my ute tuned with bigger injectors and they tell me that my stock pump is maxxed out at 240rwkw and need a bigger one, says he can open injector cycle to 100% after 4800rpm and just can't get any more fuel out of them, I was under the impression they were good for heaps more, have I got a dud or could it be something else, utes got cat, wog cooler, bigger injectors, 2nd cai, any ideas? Link to comment https://www.fordxr6turbo.com/forum/topic/44086-fuel-pump-maxxed-at-240kw/ Share on other sites More sharing options...
PURVIE Sexy Member Donating Members 524 Member For: 18y 6m 19d Gender: Male Location: Berwick, VIC Posted 01/04/08 08:17 AM Share Posted 01/04/08 08:17 AM It doesnt surprise me mate, mine maxed out around that power too if not less, ended blowing the thing up on a makeshift tune. Got the walboro, retuned, good as new! Link to comment https://www.fordxr6turbo.com/forum/topic/44086-fuel-pump-maxxed-at-240kw/#findComment-653158 Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 18y 14d Gender: Male Location: Nrth Qld Posted 01/04/08 08:47 AM Share Posted 01/04/08 08:47 AM Sounds right from what Ive heard. that's why ive done this: http://www.fordxr6turbo.com/forum/index.php?showtopic=43198 Link to comment https://www.fordxr6turbo.com/forum/topic/44086-fuel-pump-maxxed-at-240kw/#findComment-653177 Share on other sites More sharing options...
O2STOCK Donating Members 607 Member For: 19y 9m 14d Location: Brisbane Posted 01/04/08 09:14 AM Share Posted 01/04/08 09:14 AM I guess all are different, mine supported 390 RWKW but was at the limit. Have you checked the in tank sock on the bottom of the pump ? Link to comment https://www.fordxr6turbo.com/forum/topic/44086-fuel-pump-maxxed-at-240kw/#findComment-653188 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 1m 1d Gender: Male Location: @ my laptop Posted 01/04/08 10:07 AM Share Posted 01/04/08 10:07 AM how old is your fuel filter? Link to comment https://www.fordxr6turbo.com/forum/topic/44086-fuel-pump-maxxed-at-240kw/#findComment-653219 Share on other sites More sharing options...
SCRIBR Yaris member Member 4,486 Member For: 19y 8d Gender: Male Posted 01/04/08 10:41 AM Share Posted 01/04/08 10:41 AM who is your tuner.. maybe he's doing it wrong! Link to comment https://www.fordxr6turbo.com/forum/topic/44086-fuel-pump-maxxed-at-240kw/#findComment-653250 Share on other sites More sharing options...
Fry Member 123 Member For: 18y 7d Gender: Male Location: S/E Melb Posted 01/04/08 11:09 AM Author Share Posted 01/04/08 11:09 AM gettin a walbro put in now, seems to be the one to get, haven't checked the sock at bottom of pump but yeah could be blocked and fuel filter was pretty old so changed that today, my tuner has a few XR6T's done by him makin high 200's and some low 300's so maybe pumps just nackered, cheers for ideas guys, hopefull walbro fixes by prob Link to comment https://www.fordxr6turbo.com/forum/topic/44086-fuel-pump-maxxed-at-240kw/#findComment-653272 Share on other sites More sharing options...
PURVIE Sexy Member Donating Members 524 Member For: 18y 6m 19d Gender: Male Location: Berwick, VIC Posted 01/04/08 12:33 PM Share Posted 01/04/08 12:33 PM It should sort it out, when he was tuning was the car running lean or backfiring? The only other problem you may run into is your Valve springs, if you have an early model T then they are more likely to float, hence not holding boost. Link to comment https://www.fordxr6turbo.com/forum/topic/44086-fuel-pump-maxxed-at-240kw/#findComment-653320 Share on other sites More sharing options...
SCRIBR Yaris member Member 4,486 Member For: 19y 8d Gender: Male Posted 01/04/08 09:12 PM Share Posted 01/04/08 09:12 PM sounds like too much fuel being used... Link to comment https://www.fordxr6turbo.com/forum/topic/44086-fuel-pump-maxxed-at-240kw/#findComment-653395 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 1m 9d Gender: Male Location: Sydney NSW Posted 01/04/08 10:04 PM Share Posted 01/04/08 10:04 PM So it was being tuned with an old fuel filter??If your going to spend large $$ on tuning, its a good idea to first put in a new fuel filter... a new filter may have been all it needed to go 300.But also, doing the pump is a smart move regardless, hope the tune comes out well. Link to comment https://www.fordxr6turbo.com/forum/topic/44086-fuel-pump-maxxed-at-240kw/#findComment-653406 Share on other sites More sharing options...
