  • Member For: 18y 11d
just got my ute tuned with bigger injectors and they tell me that my stock pump is maxxed out at 240rwkw and need a bigger one, says he can open injector cycle to 100% after 4800rpm and just can't get any more fuel out of them, I was under the impression they were good for heaps more, have I got a dud or could it be something else, utes got cat, wog cooler, bigger injectors, 2nd cai, any ideas? :buttrock:
https://www.fordxr6turbo.com/forum/topic/44086-fuel-pump-maxxed-at-240kw/
  • Sexy Member
  • Member For: 18y 6m 23d
It doesnt surprise me mate, mine maxed out around that power too if not less, ended blowing the thing up on a makeshift tune. Got the walboro, retuned, good as new!
  • Into the laaaake
  • Member For: 18y 19d
gettin a walbro put in now, seems to be the one to get, haven't checked the sock at bottom of pump but yeah could be blocked and fuel filter was pretty old so changed that today, my tuner has a few XR6T's done by him makin high 200's and some low 300's so maybe pumps just nackered, cheers for ideas guys, hopefull walbro fixes by prob
  • Sexy Member
It should sort it out, when he was tuning was the car running lean or backfiring? The only other problem you may run into is your Valve springs, if you have an early model T then they are more likely to float, hence not holding boost.
  • Member For: 19y 1m 13d
So it was being tuned with an old fuel filter??
If your going to spend large $$ on tuning, its a good idea to first put in a new fuel filter... a new filter may have been all it needed to go 300.
But also, doing the pump is a smart move regardless, hope the tune comes out well.
