Weird Nioses
ERUP4T
  • Member For: 17y 4m 18d
Hi all.
I have just noticed when I start the car in the mornings, my care revs extremely akwardly and hence makes like an annoying rattling noise right near the gear box ( could this be my exhaust mainfolds combined with my throttel position sensor)
Also, in the mornings there is a squeeky noise coming from seemingly the front of the car (I.e fan belt or there abouts). this is so annoying.
And now I just discoverd a clanging noise on my right rear wheel. everytime the car shales this noise appears..
Im on fire with the noises lol.. my car is falling apart
All help is appreciated
Thank you
  • Member For: 17y 2m 4d
Hi all.
Thank you
I must not be insane - I get the same noises come from the front of the car - it only happens when I start it in the morning too and it seems to me like the fan belt - I also get that rattling noise which you can hear when u rev it a little and keep the revs down. I seem to get that sorta noise coming through the gear stick - but that's if you have a manual -
  • Member For: 19y 10m 27d
The sqeak will be the pulley belt at the front...and I also believe the rattle can be the exhaust cover (heat sheilds) I have this noise still..to lazy to get underneath and tighten them lol
  • Mmmmm......BOOST
  • Member For: 17y 10m 13d
check out your power steering pump ,if that's stuffed it would be noisy and also put extra load on your engine that might give you a rough cold idle
  • Member For: 18y 26d
Same problemt he sqeak noise in the morning, I have change the belts and all pulleys and it stoped and came back again, I think it the fatory belt that's the problem, im going to go after market o n the belt soon and will let you know. As for the ticking noise its the heat sheild near the cat on my T
