massiv Member 89 Member For: 17y 1m 2d Gender: Male Location: East Bentleigh Posted 31/03/08 02:00 AM Author Share Posted 31/03/08 02:00 AM My t56 is a little noisey but nothing like you discribed.... it would be interesting to compare the noise.... Im in eltham if you are interested..TristanMate sure am interested im in Diamond Creek often as my Mrs lives there! Next time im there I could give you a bell and catch up!PM me your details =) Link to comment Share on other sites More sharing options...
groper Member 611 Member For: 18y 10d Posted 31/03/08 02:25 AM Share Posted 31/03/08 02:25 AM mine doesnt make a sound above 2000rpm... all I get is some gear hash under load at low rpm below 1800-2000rpm... id say you have a problem and should get it looked at by another dealer... Link to comment Share on other sites More sharing options...
F6 381 Member 88 Member For: 17y 11m 19d Posted 31/03/08 03:18 AM Share Posted 31/03/08 03:18 AM Wasn't there a thread some months ago about the bolts coming loose on some bracket on the trans!!This may be the problem and change your gear box oil to something better. Ours was never noisey so maybe we were lucky there. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 3m 15d Gender: Male Location: Perth Posted 31/03/08 04:00 AM Share Posted 31/03/08 04:00 AM Check the bolts at the back of the gearbox. Drain the oil and fill it with 4800ml of transmax Z. Catch the oil and note how much came out. If its not full enough it will rattle like hell. Link to comment Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 2m 12d Gender: Male Location: Melbourne Posted 31/03/08 04:34 AM Share Posted 31/03/08 04:34 AM I was told NOT to put an additive like Transmax in there when it's still under warrany as Ford will try and void it if they find it (but not sure if they can tell or not?). Apparently it's an additive and is not factory recommended. All of them make a little noise at low revs, but there's definately as issue with yours. I would take it back in and be firm with them. Tell em you don't want the car back until they have fixed the problem, and if they don't fix it, ask to speak to someone else, and if they can't help you, ask who else you can speak to. If you don't give up, they'll have no choice but to spend some time dropping the box and investigating it, not just trying to 'insulate the gearstick' and muffle the sound. What a fukin idiot. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 19d Gender: Male Location: Perth Posted 31/03/08 04:44 AM Share Posted 31/03/08 04:44 AM Transmax is Dexron3 compliant trans fluid. Not an additive. They cannot void the waranty if you are using oil that complies with there specs.The insulator is a facoty fitted item. I would be draining the oil and refilling with 4800mls of Transmax or in my prefernce Royal Purple Syncromax. Syncromax WILL NOT making the box quieter than stock but it will improve shifting by about 6000%. cheersLuke Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4d Gender: Male Location: SW Sydney Posted 31/03/08 04:54 AM Share Posted 31/03/08 04:54 AM sorry for an old question, but how much is the Transmax worth, and also the Royal Purple stuff? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 19d Gender: Male Location: Perth Posted 31/03/08 05:11 AM Share Posted 31/03/08 05:11 AM http://cgi.ebay.com.au/Royal-Purple-oil-Sy...1QQcmdZViewItem Link to comment Share on other sites More sharing options...
igsta Member 371 Member For: 21y 4m 2d Gender: Male Location: Sydney Posted 31/03/08 05:33 AM Share Posted 31/03/08 05:33 AM My car did it for a few months after it was 6 months old. My car is 5 years old now and hasnt made the noise since. I did change to Transmax Z. Link to comment Share on other sites More sharing options...
Guest EGOXRT Guests Posted 31/03/08 05:58 AM Share Posted 31/03/08 05:58 AM Tranzmax Z although compatible with Dextron, will void your warranty with Ford. One is red and one is green so unless you are able to completely remove one or the other, Ford will be able to tell.I have had my box replaced as have many others here with no avail. The T56 has no factory insulation around the stick like the 5 speed did and even if it did, would make no difference. Does the gearbox operate normally or is there any other faults, jumping out of gear? Mate, you are quite welcome to come have a listen to mine and I can explain it better to you. Pm me for my details, I am in Campbellfield. Link to comment Share on other sites More sharing options...
