  • Member For: 17y 4m 18d
  EZ2CME said:
I did have plans for internals but its just all too much $$$ involved. Just going to leave it where it is for now. Not sure yet if I'll even upgrade to 19"s yet or just keep the 17"s and just go for a cheaper brake upgrade then the brembo's.
Got to stop spending money on this thing sometime and start putting that money towards things that will make me money.
yer I know what you mean but my mate has a godzilla gtr with 500hp at the wheels and I have to beat him
  • Replies 28
  DRTYBOOST said:
after my first tune my clutch lasted about 1 min, first time I gave it abit it started slipping lol that was a 288rwkw
ahh so you had work done at tims too?? what kw you up to now
  tab said:
Their website is based on using a unichip I would say....we've discovered the world isn't flat since those days!
yer so true tim exchange the unichip with a flash tuner for me at same price all up was $9970 + new spakeplugs and couple other things
  • Formerly XR6NA
  • Member For: 19y 6m 19d
Nice, good luck beating him. Will be loads of fun trying though :innocent:
yer true bit hard to beat a all wheel drive car that weighs the same as I do might need a little bit of nos just to get me past
  • Member For: 21y 7m 27d
Reading this thead brings back bad memories, Sorry daggo
I too spent close to 10K at Slackos :flick_flex:
Everything he put on the car has now be replaced. (except valve springs)
Unichip
Exhaust
42' injectors
clutch
And a few other bits and pieces
End result was 326hp on Slackos dyno and 330 hp on MCE dyno it does not read that much lower!
And his excuses why he could not produces the bigger numbers like other tuners over east at the time was that they have better fuel and better quality of air. :buttrock:
I see you have the edit, Does tim do his own tuning with the CAPA software?
Unless things have changed alot (this was back Jan 06)I would recommend you take you car else where.
Russ
I too spent close to 10K at Slackos :tonguepoke:
Unichip
Exhaust
42' injectors
clutch
And his excuses why he could not produces the bigger numbers like other tuners over east at the time was that they have better fuel and better quality of air. :stirthepot:
Russ
-have you replaced the gear because you went higher hp?
-with the tune yer he does emm himself with the capa software and there isnt much difference then I dont know who to believe now I spose all that matters is who you beat!
-might have a look around but they are priced quite well there!
  Superpursuit83 said:
Well done with the T mate... But you guys need more cylinders. :) (9psi 370rwkw)
thanks mate.
yer true but we have other benefits over xr8 1 being fuel and also I am guessing more low down torque
  XR06T said:
sounds nice. cant believe he set you up with a phase 3 and sent you out with a stock clutch!
yer wasnt the smartest thing to do he seemed to think it would hold up for a while, but had no chance
