sensoryamusia Member 398 Member For: 17y 1m 21d Gender: Male Location: leeming, PERTH Posted 15/05/08 05:59 AM Share Posted 15/05/08 05:59 AM (edited) I did this mod tuesday n sounds good I also have a aftermarket bov sittin there but dont use it. it get the flutter but not like the sound of xr2dy4 which was the more sound I was goin for but I can hear when had bonnet up a small suckin noise coming from the t-peice I think the vac line might have a small hole it in. also when I hit it hard (car is stock) at 4 1/2 over rpm I dont get the tutututu its more like the sounds of a phssst but a quick 2 drops any theories??take off your bov, block the holes up then try it matealso he's running 13psi as opposed to the stock 6psi so his will always be louder. Edited 15/05/08 06:00 AM by sensoryamusia Link to comment https://www.fordxr6turbo.com/forum/topic/43919-venting-the-stock-bov/page/6/#findComment-676442 Share on other sites More sharing options...
Howsee Donating Members 785 Member For: 17y 6m 25d Gender: Male Location: Carindale, Brisbane Posted 15/05/08 11:04 AM Share Posted 15/05/08 11:04 AM wow just had the weirdest thing happen. took off the cross over to change the vac line the first line had on was abit long so I cut it down to fit nicely took for a run n now I dont even get a tutututu it just sounds like a aftermarket bov WTF!!!that's really random - but still that's lucky as mate, I bought a turbosmart kompact boc and all it does it give the tutututututu sound (which I hate) so I'll need to change it over to get the pssst sound I want when I can be stuffed. post up an audio/video link for it for the rest of us. Link to comment https://www.fordxr6turbo.com/forum/topic/43919-venting-the-stock-bov/page/6/#findComment-676684 Share on other sites More sharing options...
Locky28 Member 59 Member For: 17y 5m 6d Gender: Male Location: Rockhampton Posted 15/05/08 11:24 AM Share Posted 15/05/08 11:24 AM Have you tried losening the spring in the BOV? Sounds like it's to tight and it's not venting. Link to comment https://www.fordxr6turbo.com/forum/topic/43919-venting-the-stock-bov/page/6/#findComment-676713 Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 18y 3d Gender: Male Location: central coast Posted 15/05/08 08:36 PM Share Posted 15/05/08 08:36 PM (edited) I did this mod tuesday n sounds good I also have a aftermarket bov sittin there but dont use it. it get the flutter but not like the sound of xr2dy4 which was the more sound I was goin for but I can hear when had bonnet up a small suckin noise coming from the t-peice I think the vac line might have a small hole it in. also when I hit it hard (car is stock) at 4 1/2 over rpm I dont get the tutututu its more like the sounds of a phssst but a quick 2 drops any theories??I might be wrong on this ,but from my experience the stock bov allows some air to run in the reverse direction at idle and under very light throttle application ,that might be the air noise you can hear that's why I don't like not running the bov have done it a couple of times and I really think it does affect the just off idle performance of the car and try replacing the crappy vacumm hose with a piece of good quality fuel hose the same inside dia. the fuel hose is reinforced so wont colapse under vacumm ,my bov seemed to work twice as good when I changed to this hose Edited 15/05/08 08:38 PM by our06t Link to comment https://www.fordxr6turbo.com/forum/topic/43919-venting-the-stock-bov/page/6/#findComment-676890 Share on other sites More sharing options...
robbo k Member 414 Member For: 17y 24d Location: Wollongong Posted 15/05/08 10:39 PM Share Posted 15/05/08 10:39 PM (edited) ta mate I might get some fuel line. I know that the vac line I got is but rubber doesnt have the threaded stuff in it. I just changed the bov back over to stock and got my other lil mod with the 4cm long vac line with bolt in the top on plug onto the t-peice. gives the tutututu sound. Edited 15/05/08 10:39 PM by robbo k Link to comment https://www.fordxr6turbo.com/forum/topic/43919-venting-the-stock-bov/page/6/#findComment-676906 Share on other sites More sharing options...
STYLZEE Member 75 Member For: 16y 11m 2d Posted 22/06/08 09:11 AM Share Posted 22/06/08 09:11 AM installation was a peice of cake with this tutorial thanks guys Link to comment https://www.fordxr6turbo.com/forum/topic/43919-venting-the-stock-bov/page/6/#findComment-696674 Share on other sites More sharing options...
hardcore Member 92 Member For: 17y 15d Gender: Male Posted 02/07/08 08:03 AM Share Posted 02/07/08 08:03 AM Did this tonight on mine, Just abit worried about the really small pipe that comes of the end of the bov. Had to jam the BOV back in so I'm hoping the small hose is still connected properly and not kinked.Should Ibe worried about this? going to drive to work tomorrow before I pull crossmember off and have a good look Link to comment https://www.fordxr6turbo.com/forum/topic/43919-venting-the-stock-bov/page/6/#findComment-700998 Share on other sites More sharing options...
xr6bo05st Member 5 Member For: 17y 4m 18d Posted 06/07/08 09:27 AM Share Posted 06/07/08 09:27 AM Where can I buy the blanking caps please? Link to comment https://www.fordxr6turbo.com/forum/topic/43919-venting-the-stock-bov/page/6/#findComment-702409 Share on other sites More sharing options...
Maximus Member 1,627 Member For: 18y 1m 20d Gender: Male Location: Slip Sliding Away Posted 06/07/08 09:56 AM Share Posted 06/07/08 09:56 AM You talking about the chair leg tips???If so then Bunnings sell them. 4 for $4ish. Get the rubber ones not the plastic.Do yourself a favor and buy some screw clamps from Supercrap so you can easily change them when you get sick of the sound Link to comment https://www.fordxr6turbo.com/forum/topic/43919-venting-the-stock-bov/page/6/#findComment-702420 Share on other sites More sharing options...
RSK Member 340 Member For: 17y 7m 18d Gender: Male Posted 14/07/08 08:14 AM Share Posted 14/07/08 08:14 AM (edited) What's the size of the vaccum line from the BOV guys!?!!!? Really wanna redo my BOV mod and mount the filter/bov over the cross over. Only way I can do this is to get a longer vaccum line and need it's size. Anyone?!?!!!?Did this tonight on mine, Just abit worried about the really small pipe that comes of the end of the bov. Had to jam the BOV back in so I'm hoping the small hose is still connected properly and not kinked.Should Ibe worried about this? going to drive to work tomorrow before I pull crossmember off and have a good lookMine is massively bent too However, I knew it was going to be bent, and before putting it back on, I tried to almost turn fold it in half, and even half folded, air still goes through really easily. Edited 14/07/08 08:16 AM by RSK Link to comment https://www.fordxr6turbo.com/forum/topic/43919-venting-the-stock-bov/page/6/#findComment-705500 Share on other sites More sharing options...
