TonyD Member 41 Member For: 14y 9m 23d Gender: Male Location: VIC Posted 04/05/11 08:39 PM Share Posted 04/05/11 08:39 PM See attached image for more explanation =] Link to comment Share on other sites More sharing options...
c0lezy Donating Members 115 Member For: 16y 1m 24d Gender: Male Location: West Posted 05/05/11 06:26 AM Share Posted 05/05/11 06:26 AM On 04/05/2011 at 1:16 PM, LazyBrennan said: How exactly do I turn it around? The smaller hose is not long enough. It just kinks. Witch pipe are you talking about that would be sucking in unfiltered air?do you remove the crossover? Link to comment Share on other sites More sharing options...
LazyBrennan Donating Members 683 Member For: 14y 20d Gender: Male Location: Baldivis, Wait Ages. Posted 05/05/11 10:57 AM Share Posted 05/05/11 10:57 AM Cheers for that pic mate. I ended up just cutting that little hose shorter and clamping it down. It sounds louder now.Yeah I am taking the cross over off. I have big hands and a short fuse so I wouldnt be able to get it in with out taking the cross over off But yeah the small thin hose that's on the opposite side of the BOV is so short I cant turn it around with out it kinking. It is all in now and loving the sound. Link to comment Share on other sites More sharing options...
Maximus Member 1,627 Member For: 18y 1m Gender: Male Location: Slip Sliding Away Posted 05/05/11 12:32 PM Share Posted 05/05/11 12:32 PM Lazy, you also have broken the plastic PCV Valve that runs back into the cross over.Look mid way down in this pic of yours and that shiny bit on the left should have a thread on it into the crossover.The thread is probably broken off in the crossover now.Use a flat head screwdriver to twist it back out.Here is the thread I started when I found mine was broken.Part number for the little bit that screws into the crossover is BA 9V684A and was $23 from Ford. Link to comment Share on other sites More sharing options...
LazyBrennan Donating Members 683 Member For: 14y 20d Gender: Male Location: Baldivis, Wait Ages. Posted 05/05/11 01:17 PM Share Posted 05/05/11 01:17 PM Yeah mate that was another problem and another story haha. I got the connection from ford for 17 bucks Perth falcons member discount. But yeah it was a easy fix... Just annoying. All good now though :d Link to comment Share on other sites More sharing options...
Maximus Member 1,627 Member For: 18y 1m Gender: Male Location: Slip Sliding Away Posted 06/05/11 06:40 AM Share Posted 06/05/11 06:40 AM Sweet. Just wasn't sure if you noticed. Link to comment Share on other sites More sharing options...
GPW Member 20 Member For: 14y 4m 28d Posted 10/06/11 03:30 PM Share Posted 10/06/11 03:30 PM Have just bented the stock BOV on my FG XR6T. Used the below parts:1. A bunnings 25mm rubber chair stopper (wich tapers to a wider end),which is 25mm internally. (Pkt of 4 for $5)2. A 20-38MM metal hose clamp thingy to secure the stopper onto the Crossover end opening, once the piping was removed - $1.503. A 25mm K&N Breather - $35The last FG XR6T I had I left stock, so for this FG was a much liked mod as I actually heard some noise from underneath the bonnet without having to boost hard.Makes a long psssssccccchhhhhhhhhhhhhhhh sound when you back off the boost/accelerator - not as crisp a sounds as I would like it {ideas for this sound's welcome}, but not bad for under $50.Best part - completely reversable if needed, and also, no noise when cruising/slowly acceleration, just when you want it.Cheers Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 3m 16d Gender: Male Location: Melbourne Posted 11/07/11 09:16 AM Share Posted 11/07/11 09:16 AM nice write up GPWchuck a pic up for the FGers out there too Link to comment Share on other sites More sharing options...
psifed2 Member 69 Member For: 14y 1m 7d Posted 15/07/11 02:36 PM Share Posted 15/07/11 02:36 PM My set up is bunnings plugs on both of the tubes comin off the crossovers back and the front one going under neath to the BOV, completely removed the BOV. 5mm hole in the plug at the back and put a screw in the vacume hose. Is this okay? Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 10m 16d Gender: Male Location: Melbourne Posted 15/07/11 07:57 PM Author Share Posted 15/07/11 07:57 PM Doesn't sound like it, can you post up a pick?This mod has almost become obsolete now that you can buy the knockoff turbosmart kompacts for $60. Link to comment Share on other sites More sharing options...
