  • Member For: 18y 6m 27d
yea I didn't realise it had 3/8 on the top of the stoppers in the pic.. couldn't edit my post.. thanks mate
Just did this,, I couldn't find the rubber stoppers so I found these plastic blockers that you use for gardening/sprinkler installations.. they have a lip on the bottom to prevent them from popping out once the clamp is on.. I hardly got any new sound at all.. I didn't filter it just blocked of both pipes and blocked off the vacume line.. were did I go wrong?
  • Forged Member
  • Member For: 18y 2m 17d
Yes, they are two completely different things.
The wastegate is used to control the boost a turbo produces by diverting exhaust gas either through (more boost) or past (less boost) the turbo.
A BOV is used to reduce the amount of pressure build-up in the intake piping when the throttle has closed. When the throttle closes there is a lot of pressure still in the intake, the BOV vents the excess pressurized air (either to atmosphere or back into the intake at the front of the turbo)
  • Member For: 16y 4m 23d
So you can/have to have both
Because I bought my BA 6T already modified and been told the Waste Gate makes the loud noise and flutters on my car
  • Forged Member
I'd say the person that told you that should've asked the same question you did, cos they obviously don't know the difference between a BOV and Wastegate!
  • Member For: 16y 4m 16d
just vented bov and sounds heaps cooler then stock hehe but I got filter on the left and vac line to the right just different to the pic but does the job
