  • 1 month later...
  • Member For: 16y 5m 6d
so... I want the hole pshhh sound, I have a 2004 BA xr6t auto stock, if I follow the first post in this thread I should get it correct? I dont really understand it thow... should I maybe just buy a bov?
http://cgi.ebay.com.au/FORD-FALCON-BA-BF-X...A1%7C240%3A1318
  • 1 month later...
  • Member For: 17y 10m 21d
If you want a quieter Pchh sound with a bit of flutter then just vent the stock bov. If you want a Loud Pchh sound then buy an aftermarket turbosmart or something with a big trumpet on it.
  • Cryptic Clothing Company
  • Member For: 16y 9m 6d
or just block it off all together and throw a pod infront of the tubro... dose it
Edited by typhoon_freak
  • Member For: 17y 4m 5d
I took my plum-back line off (and plugged it) of my BOV for the time it takes to use a tank of fuel and it made everything WORSE, made horrible whooshing sounds when backing off the throttle, no crisp "Pssht" sound that I was expecting, fuel usage went from 550km to a tank to 400km a tank, (driving to and from work up and down freeway) it felt slower on accelleration and even at idle the discharge side of the BOV was letting pressure out, so imagine how much air it would have been passing at full noise!
I hooked my plum-back line up and left it after that, much better for me.
Anyone else had similar effects?
  • 2 weeks later...
  • 3 weeks later...
Dude an FG looks ever easier. You don't even have to pull the cross over off and you could pretty much fit what ever bov you like.
  • Member For: 16y 9m 23d
yeah mate fg is so damn easy, did mine today sounds ok, all you have to do is take a piece of pipe off 1 clamp an put a filter on your intake cross over or block it off
  • Member For: 17y 3m 30d
even if your leaking air theory is correct, hooking up the vent pipe back to standard isn't going to fix that, the leak would still be there.
  • Member For: 18y 6m 19d
anyone know the size of the stopper they are put into the pipes? I can't see it anywwere mentioned
