markxr6t Member 476 Member For: 20y 4m 7d Location: Perth WA Posted 11/01/05 02:53 PM Share Posted 11/01/05 02:53 PM I had the AVG consumption reading below 8 litres/100k the other day on the highway!!Normally I can get it down to 9. One trick is stay a little below 100k as the turbo starts to cause consumption to go up at about 2000 rpm - which is about 100kph in 4th gear in my auto.<{POST_SNAPBACK}>I tried that today and you are spot on.At 98kmh the engine is doing 1950 rpm and is showing around 9 L per 100k and at 105 kmh its doing 10-11 L per 100k. <{POST_SNAPBACK}>Did a 300km trip on the weekend, (Bridgetown to Perth), cruise control on 115km/hr, air con on and flooring it in 3rd or 4th at every overtaking opportunity. Got 10.1 l/100km by the trip meter and confirmed with 10.2 l/100km with a refill. It was a 27 degree day - possible tail windFunnily enough, on the way there, same driving style, I got 11.2 L/100km. It was 37 degrees that day and there may have been a head wind. I'm still stoked though as my consumption around town ranges from 13.5 l/100km (normal driving, occasional fang) to 17 l/100 (fanging it, occasionally normal)I'd like to know if piggybacks or edit (say to 8psi) improve this to (obviously if you're not using the extra power all the time)Mark Link to comment Share on other sites More sharing options...
markxr6t Member 476 Member For: 20y 4m 7d Location: Perth WA Posted 11/01/05 02:57 PM Share Posted 11/01/05 02:57 PM I had the AVG consumption reading below 8 litres/100k the other day on the highway!!Normally I can get it down to 9. One trick is stay a little below 100k as the turbo starts to cause consumption to go up at about 2000 rpm - which is about 100kph in 4th gear in my auto.<{POST_SNAPBACK}>I tried that today and you are spot on.At 98kmh the engine is doing 1950 rpm and is showing around 9 L per 100k and at 105 kmh its doing 10-11 L per 100k. <{POST_SNAPBACK}>Did a 300km trip on the weekend, (Bridgetown to Perth), cruise control on 115km/hr, air con on and flooring it in 3rd or 4th at every overtaking opportunity. Got 10.1 l/100km by the trip meter and confirmed with 10.2 l/100km with a refill. It was a 27 degree day - possible tail wind. I was stoked!Funnily enough, on the way there, same driving style, I got 11.2 L/100km. It was 37 degrees that day and there may have been a head wind. I'm still stoked though as my consumption around town ranges from 13.5 l/100km (normal driving, occasional fang) to 17 l/100 (fanging it, occasionally normal)I'd also like to know if piggybacks or edit (say to 8psi) improve this????? (obviously if you're not using the extra power all the time)Mark Link to comment Share on other sites More sharing options...
FPV 521 FPV521 Member 989 Member For: 20y 6m 3d Gender: Male Posted 11/01/05 09:32 PM Share Posted 11/01/05 09:32 PM Drag is proportional to the square of the speed so you would expect a big difference between the fuel used at 95 to 105km/h95 *95 = 9025 ie 9 litres / 100km105 * 105 = 11025 ie 11 litres/100kmErr, you can't just square kilometres per hour and get litres per 100km, the units are all wrong, and anyway, by that logic, 150 k/h would suck 22.5 litres/100km, and at 60 k/h you get 3.6 litres/100km<{POST_SNAPBACK}> Link to comment Share on other sites More sharing options...
RAPHOON Donating Members 1,776 Member For: 21y 8m 9d Posted 11/01/05 10:35 PM Share Posted 11/01/05 10:35 PM I had the AVG consumption reading below 8 litres/100k the other day on the highway!!Normally I can get it down to 9. One trick is stay a little below 100k as the turbo starts to cause consumption to go up at about 2000 rpm - which is about 100kph in 4th gear in my auto.I tried that today and you are spot on.At 98kmh the engine is doing 1950 rpm and is showing around 9 L per 100k and at 105 kmh its doing 10-11 L per 100k. Did a 300km trip on the weekend, (Bridgetown to Perth), cruise control on 115km/hr, air con on and flooring it in 3rd or 4th at every overtaking opportunity. Got 10.1 l/100km by the trip meter and confirmed with 10.2 l/100km with a refill. It was a 27 degree day - possible tail wind. I was stoked!Funnily enough, on the way there, same driving style, I got 11.2 L/100km. It was 37 degrees that day and there may have been a head wind. I'm still stoked though as my consumption around town ranges from 13.5 l/100km (normal driving, occasional fang) to 17 l/100 (fanging it, occasionally normal)I'd also like to know if piggybacks or edit (say to 8psi) improve this????? (obviously if you're not using the extra power all the time)MarkThe standard tunes in the EDIT flashbox appear to be running richer than stock. I have found that my fuel consumption has increased since the EDIT, even when taking into account the fanging factor.This will change once the car has been custom tuned to better A/F ratios. Link to comment Share on other sites More sharing options...
Guest PSIXR6 Guests Posted 11/01/05 11:20 PM Share Posted 11/01/05 11:20 PM Only suggestion on fuel consumption is Ford should have put a bigger tank in it, filling it up every 2-3 days becomes annoying.<{POST_SNAPBACK}>Hhhmmmmm, I AGREE also. My average is now down to about 13.5l/100km~allen Link to comment Share on other sites More sharing options...
velociTy Team Velocity Member 1,202 Member For: 20y 5m 8d Gender: Male Location: Margs WA Posted 12/01/05 12:34 AM Share Posted 12/01/05 12:34 AM Allen that's about what I am getting around town. I would have expected better but it is still a pup I guess<{POST_SNAPBACK}>ive done 2250 ks in mine and geting about the same figures as you Link to comment Share on other sites More sharing options...
phantomchic Just because it is, doesn't mean it should be..... Lifetime Members 14,092 Member For: 20y 5m 24d Gender: Female Location: Noosa QLD Posted 12/01/05 04:08 AM Share Posted 12/01/05 04:08 AM Guages, gadgets and read outs are interesting, BUT I still believe the old method of run the tank down to E, do a full re-fill, reset the tripmeter to 0, then on the next refill you will see how much fuel and K's you are using per tank. Link to comment Share on other sites More sharing options...
Ford_Power Member 798 Member For: 21y 11m 5d Posted 12/01/05 08:45 AM Share Posted 12/01/05 08:45 AM My car has done 13500 odd kms and the dash readout is 14.9L/100kmRoss Link to comment Share on other sites More sharing options...
F6 RAPID Formerly Turbo6 Donating Members 2,332 Member For: 22y 2m Location: North Brisbane Posted 12/01/05 10:32 AM Share Posted 12/01/05 10:32 AM Buy a Prius if you really care how much fuel it uses - gotta have it. Link to comment Share on other sites More sharing options...
djgelling Donating Members 128 Member For: 22y 1m 14d Gender: Male Location: Adelaide Posted 17/01/05 10:42 AM Share Posted 17/01/05 10:42 AM Hi Guys Just wondering what sought of fuel usage is common in the T. I am averaging around 18l/100km around town and about 12l/100km highway. Does this sound about right considering only 2200 kms on the clock?Without reading the rest of the replies and risking a flaming , I'll add my observations:Prior to 15,000km Service: City 13.6 l/100km (pump) outer suburbs mainly. Highway 11.3 l/100km (pump)After 15,000km Service: Highway 10.1 l/100km (pump) cruising 115km/h on Speedo (112km/h real world). City Cycle, I don't know yet. Link to comment Share on other sites More sharing options...
