1600dave Donating Members 872 Member For: 14y 2m 23d Posted 13/08/12 07:23 AM Share Posted 13/08/12 07:23 AM They can't be out by a few litres. Maybe a couple hundred hundred mil max.Just going by what I've seen from filling various sized plastic jerry cans.Didn't believe it so checked it later on using water and the markings on the jerry can weren't far off. Link to comment Share on other sites More sharing options...
PookeyMaster Donating Members 1,531 Member For: 14y 3m 13d Gender: Male Location: Parramatta, NSW Posted 13/08/12 01:00 PM Share Posted 13/08/12 01:00 PM Check actual consumption. Fill up to first click, reset trip, drive, fill up again to first click, record litres used and km driven off trip. Only true way to calculate true consumption.I have to hold the nozzle half in. If I push it in all the way, it clicks after delivering only a litre or two... Link to comment Share on other sites More sharing options...
T-Rex Donating Members 98 Member For: 13y 2m 8d Gender: Male Posted 26/08/12 09:38 AM Share Posted 26/08/12 09:38 AM My computer reads 17 and a halfish and going off odo I'm only getting 300 maybe less to a tank in 80/20 urban/highway driving (havent gone anywhere long range yet), with not a lot of street bashing, by my calculations (which are probably wrong) that should be around the 20l per 100 mark. Link to comment Share on other sites More sharing options...
PSI O6T Donating Members 440 Member For: 12y 6m 20d Gender: Male Location: sydney Posted 28/09/12 03:59 PM Share Posted 28/09/12 03:59 PM 19.5 lt per 100 ba xr6t 106.000 klm just had full service including k&n filter , using premium 95 atmIve used about half tank and only done 100 klms Went from 3/4 to 1/4 in 100 klmsWork is about 3klms away, short trips are killing it. Will a tune help this at all Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 4m 11d Gender: Male Location: SE Melbourne Posted 28/09/12 10:46 PM Share Posted 28/09/12 10:46 PM Get a pushy. Link to comment Share on other sites More sharing options...
Never had any say Panda I <3 Floods Silver Donating Members 11,198 Member For: 13y 8m 1d Gender: Male Location: South West QLD Posted 29/09/12 01:56 AM Share Posted 29/09/12 01:56 AM 3kms?And you're driving?Car isn't even gonna go close to warming up in that time.+ 2 for pushy.. Or walk. 1 Link to comment Share on other sites More sharing options...
PSI O6T Donating Members 440 Member For: 12y 6m 20d Gender: Male Location: sydney Posted 29/09/12 04:19 AM Share Posted 29/09/12 04:19 AM where I live if I walk or ride a pushy ill get pumped by ass bandits.....I get home at 6am and I have to go through bonnyrigg,lol Link to comment Share on other sites More sharing options...
Kevilam Member 8 Member For: 12y 6m 26d Gender: Male Posted 29/09/12 04:34 AM Share Posted 29/09/12 04:34 AM where I live if I walk or ride a pushy ill get pumped by ass bandits.....I get home at 6am and I have to go through bonnyrigg,lolI'd feel safer in Bonny than in Fairfield lol Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 2d Gender: Male Posted 29/09/12 06:00 AM Share Posted 29/09/12 06:00 AM I have been playing around with fuel economy for the last few weeks in my G6eT and have always played with it via tuning in my other cars.For starters if you dont have a wideband air/fuel ratio meter you really don't know what the car is doing whist in the low rpm/cruise areas. A good wideband will let you know if you are running the correct a/fuel ratio and if your narrowband is working as intended.What I have done is remove the factory narrowband and now running an Innovate LC1 in place of my narrowband (it can put out a narrow band signal which can be programmed also). I have adjusted the output on the LC1 so it runs at around 16:1 on cruise instead of 14.7:1. It does not give alot of fuel benefit but it does give for me another 30 to 50km per tank.I also have HP Tuner so I can adjust other things like spark advance in the cruise area. My vehicle had been tuned to 350rwkw by a workshop and for some reason the advance in the cruise areas was too retarded for my liking. It was around 38 degrees in the cruise areas.I looked at the stock factory spark maps and they were alot more advanced so I adjusted the cruise areas to around 50 degrees advance like the factory has it and like I would expect the map should look like. The car drives alot better now and I think this has bought back a bit of fuel economy that was lost from the workshop tune. I dont think many workshops really know much about the economy side of things and can sometimes inadvertantly make economy worse by touching areas of the tunes which are better left alone.So now even with Nizpro drilled injectors I have gotten another 70km per tank on my route from the minor adjustment I have made. My next step is to swap out the Nizpros for some GT500 non drilled injectors to see what improvement comes from that. I dont like the nizpros drilled injector but in saying the design of the EV14 injector is pretty good when you can butcher the spray holes and still get the car to lean out to 18:1 air fuel ratio and still drive with no misfire.I do everything in stages and test to see what the gains are. I am around the 500km per tank doing 30km trips in light to medium traffic.Just making sure that the car performs as intended from the factory, ie getting 14.7 at cruise and making sure you have the correct factory advance settings should yield acceptable economy. If your tune has been butchered it will take a big hit in economy. Link to comment Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 5m 13d Posted 30/09/12 01:46 AM Share Posted 30/09/12 01:46 AM ^^ let me know when you may be interested in getting rid of those nizpro injectors, if its in a couple of months time will be pretty interested.On topic, I reset my car the other day and seems like my trip computer actually reads the same as my actual consumption now. I kind of wish this didn't happen as you feel better looking at 12L/100 than 14-15 but still using the same amount of fuel lol.Can't seem to get it much lower than that as these cars are just too much fun to drive. Link to comment Share on other sites More sharing options...
