  • Replies 39
  • Member For: 19y 8m 20d
Well done. The MPH is strong too.
As David said, the 10 sec pass is just a matter of getting that launch and 1/2 track run sorted. My 10.8 sec pass was achieved with a 1.53 60 footer & 6.94 half track time!! I wish I had your 128 MPH.
Good fresh rubber and a well prepped track will make a big difference.
  • Member For: 19y 26d
I'm using the handbrake as well as foot hard on the brake but it's still managing to creep forward not in the sense of the brakes not holding but the actual front runners sliding.
Any advice on what could be done with these standard 6 SPEED AUTO'S in leaving the line on at least a couple of pounds of boost
  • Forged Member
  • Member For: 18y 3m 26d
I noticed the track was quite slippery last night too, especially the Rocket (right hand) lane
  • Member For: 21y 6d
I would adjust your hand brake a bit more, I think the t04z must be taking a bit more to build boost,
but you must have some boost to run a 1.71 60ft.
with your brakes on hard, and your handbrake on, your back brakes should be locked, it should not need to use your fronts to hold it.
David
For some strange reason the front wheels are sliding I was told cause of the front runners and being a thread based tyre they tend to slide .
I've corrected that problem by getting wider front runners and adjusted the handbrake heaps more.
XT Brakes are shocking might go back to brembo brakes with street slicks again with that new suspension setup
its up to you, but if you are sliding the frontrunners, the front brakes are holding,(you have to push real hard to get the back brakes to hold, as well as the hand brake) the set up you have with the slicks, are what will work the best, I think if you get a clean 1st to second change you should have a good shot at a ten, you need to shift at about 4000 rpm in first to catch second before the limiter, also with slicks you can be more agressive down low in the rpm with boost, you should have 21psi at 4000, you will not see this boost in first at the drags, but it will ramp up a lot faster,and that will help the second half of your 60ft.
Hope it helps
David
Edited by blueboost
Thanks mate
Well I've got all night to try new things might take your advice this Wednesday
if I don't break the 10's
I'm still impressed with my results and proud of my car
from a 12.7 118MPH to 11.2 128MPH
Finally got my plates that have been with me for almost 10 years but sold them with a car I previously owned so it would be nice to crack a 10 with BLUUOA (Blew You Away)
Edited by BLUUOA
  BLUUOA said:
Thanks mate
goodluck with it, and you have done well.
David
