  • Member For: 17y 4m 29d
just wondering if anyone has used/still using this cam and if it is worth gettting it or not I am all about taking stress away from the turbo.
Standard Ford BA 6 cyl valve timing:
Advertised Inlet duration - 251 degrees
Advertised Exhaust duration - 251 degrees
Duration at .050" lift - 173.5 degrees
Lobe lift - inlet and exhaust - .212"
Valve lift - inlet and exhaust - .432"
Atomic #306550 valve timing:
Advertised Inlet duration - 257 degrees
Advertised Exhaust duration - 257 degrees
Duration at .050" lift - 196 degrees
Lobe lift - inlet and exhaust - .223"
Valve lift - inlet and exhaust - .453"
https://www.fordxr6turbo.com/forum/topic/43875-atomic-cams/
  • Member For: 19y 6m 19d
I run these cams in a built motor....
could not be happier with them...
I am not 100%sure how much power I got out of them as I did alot of work at once. but I do know that it is very smooth and good midrange power over the standard built motor.
https://www.fordxr6turbo.com/forum/topic/43875-atomic-cams/#findComment-650067
  • Hench, but no longer shredded or tanned.
  • Member For: 18y 3m 1d
Any chance of a sound clip?
I wanna hear a xr6t with cams as I have a set waiting to go in.
https://www.fordxr6turbo.com/forum/topic/43875-atomic-cams/#findComment-650138
  • Member For: 18y 11m 19d
It would be quite interesting to see a back to back comparison, before and after, with these Camshaft's.
There's alot more of these car's nowaday's making 400+ rear wheel kilowatts, and a set of Cam's could make a reasonable upgrade here in power, for the dollar's spent.
Maybe Atomic could come to the party and show some before and after result's?
https://www.fordxr6turbo.com/forum/topic/43875-atomic-cams/#findComment-650188
If you could even get 10 kilowatts at the wheel's from fitting them to a "400+" set up, you'd have to be pretty happy, considering how expensive it get's to make more power from there.
I think they were somewhere around the $1000 mark supplied for the Atomic's, plus I'd guesstimate another say $500 (!?) to have them fitted and have your Tune "touched up" to suit.
Good value.
https://www.fordxr6turbo.com/forum/topic/43875-atomic-cams/#findComment-650418
I think they're actually around 1400$
(700 a cam)
Don't quote me on it though.
https://www.fordxr6turbo.com/forum/topic/43875-atomic-cams/#findComment-650449
