  • www.australianflag.org.au
  • Member For: 19y 9m 27d
The three inch will be a retriction from the wastegate back.
scotty
  • Replies 32
  • Member For: 17y 4m 16d
scotty
Good call mate!
Senna, it's running a T04E, unsure of the exact specs though. I know that it should be ok for at least 300rwkw.
Edited by private9
  • Forged Member
  • Member For: 18y 3m 7d
hmmm, T04E is a decent turbo for the 4.0L, still decently responsive, and a 3" wil be ok, but if you follow the path of 3.5" with a 5" bodied cat - over 300 is achievable with the right intake - either way it will be a bloody quick street car! :shakefist:
  • Member For: 18y 9m 29d
I made 348RWKW in my ute with a 3 ince X force.
I had orded a 3.5 ince got ripped off a the shop did't find out till the cat converter failed 1year later.
  • Member For: 18y 11m 24d
  private9 said:
No worries and thanks for the advice so far!
It's an AU Falcon engine with a Snort stage 3 turbo kit on it. Currently running 210rwkw on 7psi and an overly rich tune. This is through a factory press bent exhaust, and as I want to do an exhaust next, I was just curious where a 3" will become a limitation.
Just go for a 3inch system to keep costs down and it will mate up to the Snort kits dump pipe and external gate.
Have you built the motor or is it a stocker?
Basically your turbo system is alot better flowing and larger than the standard xr6t set up so your gains from just fitting a 3inch exhaust will be better.
I built an ED turbo awile back, it made just over 300 on 14psi, with a similar set up to Snorts kit, and through a 3inch custom dump/external wgate and 2.5inch redback cat back.
You'll be fine with the 3inch, go for it
  senna_T said:
hmmm, T04E is a decent turbo for the 4.0L, still decently responsive, and a 3" wil be ok, but if you follow the path of 3.5" with a 5" bodied cat - over 300 is achievable with the right intake - either way it will be a bloody quick street car! :spoton:
Thanks mate, that's the plan! I've already got a decent cat for it (pretty sure it's a 5" body) waiting in the shed, so I've just got to pull my finger out and get the exhaust done!
Thanks mate - I think a 3" should be fine then. It's a standard low km AU2 bottom end in an EB. They're are a few people getting about with 300+ on standard AU bottom ends without trouble.
I'd like to see close to this, and I'm pretty sure the combo is more than up to it. I won't push for more though until I sort out a gearbox!
  • Member For: 18y 1m 27d
  private9 said:
well, you're right mate! I just did the maths and got the following results:
Surface area in square inches for each exhaust size:
Twin 2.25 = 10.5
Single 3" = 7.1
Single 3.5" = 15.7
Single 4" = 24.6
Aside from getting higher quality mufflers, why would anyone upgrade to a 3" considering that the pipework itself is less restrictive in standard form? Note, I am only talking about the pipework, not mufflers.
Thanks,
Justin.
Correction on the above calculated square inches. Note no reference is made for wall thickness of the tubing which does put a twin 2 1/4" closer in overall size/flow to a single 3'
Twin 2 1/4" 7.95
Twin 2 1/2" 9.81
Single 3" 7.06
Single 3 1/2" 9.62
Single 4" 12.56
This depends on the supplier of tubing, can be as small as 1.2mm up to 2.0mm.
It's been a few years since I was in the exhaust industry, but I think 1.6mm was a fairly standard size for 2-2 1/2" tubing.
