outdoor34 Member 15 Member For: 18y 2m 4d Gender: Male Location: Rockingham W.A Posted 21/03/08 02:11 AM Share Posted 21/03/08 02:11 AM HiThe other day took my xr6t for a quick drive after the 105km service gave a bit of stick a few times, then on the last time I was excelerating heard a loud woosh sound like something depressureing, then lost all my power, and have got a noise, like a exhaust leak comming from the drivers side rear of the engine sounds like it is under the rear heat shield,, checked all my clamps and hoses, cannot find anything, my car is stock except for a custom 10psi tune,any ideas would be appreciated. Link to comment https://www.fordxr6turbo.com/forum/topic/43792-loud-woosh-and-no-power/ Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 10m 15d Gender: Male Location: The 8th Dimension Posted 21/03/08 02:22 AM Share Posted 21/03/08 02:22 AM Have you replaced the factory wire hose clamps with proper worm gear or T-bolt clamps.As the symptoms sounds like a hose is popped off Link to comment https://www.fordxr6turbo.com/forum/topic/43792-loud-woosh-and-no-power/#findComment-648528 Share on other sites More sharing options...
xrdreaming Lifetime Members 1,693 Member For: 22y 3m 23d Gender: Male Location: Melbourne Posted 21/03/08 02:25 AM Share Posted 21/03/08 02:25 AM Also check your turbo housing and manifold bolts after the hoses mate. Link to comment https://www.fordxr6turbo.com/forum/topic/43792-loud-woosh-and-no-power/#findComment-648530 Share on other sites More sharing options...
outdoor34 Member 15 Member For: 18y 2m 4d Gender: Male Location: Rockingham W.A Posted 21/03/08 02:41 AM Author Share Posted 21/03/08 02:41 AM I have checked all the clamps, jacked the car up and grabbed the turbo delivery hose when the car waas running and gave it a good wobble I did not seem to be loose or did the noise change,, which I thought the noise would change if the hose had popped,,, as far as my clamps go they are still the stock ones keep meaning to get the worm type but have not got around to it yet Link to comment https://www.fordxr6turbo.com/forum/topic/43792-loud-woosh-and-no-power/#findComment-648539 Share on other sites More sharing options...
outdoor34 Member 15 Member For: 18y 2m 4d Gender: Male Location: Rockingham W.A Posted 21/03/08 02:44 AM Author Share Posted 21/03/08 02:44 AM the funny thing was I had just had the car serviced were I asked them to check all the manifold bolts were tight , when I checked them after this had happened I found the rear top exhaust bolt only hanging in by a few threads,, totally obvious by sight alone that it was loose Link to comment https://www.fordxr6turbo.com/forum/topic/43792-loud-woosh-and-no-power/#findComment-648540 Share on other sites More sharing options...
SAM80R Member 11 Member For: 16y 7m 13d Gender: Male Location: Newcastle Posted 05/03/09 02:10 AM Share Posted 05/03/09 02:10 AM same here. Mine was meant to have the bolt tightened according to service manual, but there was quite a few that were loose. Link to comment https://www.fordxr6turbo.com/forum/topic/43792-loud-woosh-and-no-power/#findComment-835688 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 28d Gender: Male Location: Probably above atmospheric pressure Posted 05/03/09 02:40 PM Share Posted 05/03/09 02:40 PM Watch out for old dead threads mate! Almost a year on this one, though nothing changes in regards to Ford service hey. I bet they didn't do my bolts either :/ Link to comment https://www.fordxr6turbo.com/forum/topic/43792-loud-woosh-and-no-power/#findComment-836293 Share on other sites More sharing options...
The_Bogan Donating Members 881 Member For: 18y 1m 19d Gender: Male Location: Brisbane, Queensland Posted 06/03/09 12:11 AM Share Posted 06/03/09 12:11 AM check the quality of your pressure side pipes, you may have a split in on of them if it happened all of a sudden! Link to comment https://www.fordxr6turbo.com/forum/topic/43792-loud-woosh-and-no-power/#findComment-836384 Share on other sites More sharing options...
Scrotus Member 156 Member For: 16y 9m 10d Gender: Male Location: Adelaide Posted 06/03/09 06:12 AM Share Posted 06/03/09 06:12 AM What do you expect for $375 service - that's what I got quoted anyway for 75,000km service. what a joke. Link to comment https://www.fordxr6turbo.com/forum/topic/43792-loud-woosh-and-no-power/#findComment-836606 Share on other sites More sharing options...
