Engine Cuts Out At Any Speed Starts, Any Thoughts?
80 RPM
  • Replies 22
  • Member For: 18y 11m 15d
I have had it happen to me a couple of times, it either just stalls or it splutters when you put your foot on the gas then all of a sudden will work fine again. Try this, when the car is off, turn the key to on but dont start the car, turn it to off again, then push the accelerator to the floor and hold it, now try and start the car with the your foot still on the accelerator, the car will kick over but wont start do this for about 10 seconds then turn the key to off again. now just start the car like normal. It will reset the TPS, my mate who is a mechanic for ford told me to do this. I do it about once a month and have never had it happen to me since.
  • Sucker
  • Moderating Team
  • Member For: 20y 8m 2d
I think that actually resets the cam phase sensors or something like that....so if it works for you, you may have a different problem.
Either way though if solves your problem then that's all that matters I guess :sofa:
  • Member For: 17y 1m 17d
I asked the ford service guy about this and he said it doesn't reset your TPS but it did do something else probably what tabs described
Tow truck is coming this morning to take it to ford!
To think I bought a near new car so I could shelve all the tow truck numbers!
Brisbane tow trucks would have gone out of business since my mazda was off the road! but alas the ford will keep them in business!
will post ford dignosis when known
Regards,
Ryan.
Not good Ryan. Keep us up to speed with it mate.
the quick update ford want 600 bucks for the tps sensor and that's what the problem was
I told him to go back and check again because I was quoted 168 for the part the day before when I rang spares
Me's thinks they f%&^#d it removing it and now need to replace the throttle body because they don't want to retap out the screws because they cross thread easily
as always watch this space
Ryan.(one very pissed off ford owner)
Edited by 80 RPM
I read somewhere it is easy to change the only thing is when rescrewing the new TPS it is very easy to strip the threads in the plastic, hence why ford probably charge for the throttle body as well
two screws I think but don't quote me on that
BTW Service got back to me (I rung them) They have agreed that I was correct and are putting the tps only in tommorow to make sure everything works as it should.
Ryno.
  • Moar Powar Babeh
  • Member For: 19y 3m 4d
The tps is very easy to replace. You will strip/break the screw if you do it when the car is cold. If you get the motor nice and warm it will help soften the loctite. Alternativly you can warm the area around the screws on the throttle body with a small heating torch or gas ignitor and this will have the same effect.
Loctite also make a releasing agent that you can spray on the threads and it will wick in and breakdown the bond between the screw and the loctite. This is pretty expensive stuff tho.
I dont know if the pcm self calibrates on startup or you have to get the tps calibrated by your friendly dealer once it been replaced.
cheers
Luke
