NVT Formerly EGOBFXR6 Donating Members 1,111 Member For: 17y 3m 14d Gender: Male Location: Perth, WA Posted 18/03/08 01:32 PM Share Posted 18/03/08 01:32 PM Hey guys,Saw on a classified site a fella who was selling a turbo assembly. He says its for a BA, so I'm assuming it will fit my BF?There is a pic attached at the bottom of the post - is this all I need? How much will it cost to have it fitted and such?He said, " I have for sale a GENUINE XR6 Turbo Kit. The Turbo is BRAND NEW (cost around $4100 to buy from Ford alone) The intercooler, exhaust manafold and top manafold were off a new XR6 Turbo that upgraded to aftermarket parts.(all parts are in perfect working order, the intercooler has a couple of small scratches but you can't see it in the car anyway) As far as I know, besides the air pipes and a retune of the factory computer, this is everything you need for the conversion"He is asking $1999 for just whats shown - good deal? How much will I be looking at in total?Cheers,Dan Link to comment https://www.fordxr6turbo.com/forum/topic/43711-turboing-my-bf-xr6-na/ Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 22d Gender: Male Location: Perth Posted 18/03/08 01:37 PM Share Posted 18/03/08 01:37 PM I am going to supercharge my sons XR6 soon with a capa unit . Aim for about 220rwkw I think that would be a better option. Link to comment https://www.fordxr6turbo.com/forum/topic/43711-turboing-my-bf-xr6-na/#findComment-647463 Share on other sites More sharing options...
fordboy1981 Donating Members 2,075 Member For: 22y 4m 1d Gender: Male Location: Sydney, NSW Posted 18/03/08 05:52 PM Share Posted 18/03/08 05:52 PM if you want any kind of resale dude, just sell the N/A and buy a runout BFII turbo... Ford are giving awesome deals at the moment from what I hear... Link to comment https://www.fordxr6turbo.com/forum/topic/43711-turboing-my-bf-xr6-na/#findComment-647484 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 11m 29d Gender: Male Location: Sydney NSW Posted 18/03/08 09:32 PM Share Posted 18/03/08 09:32 PM 2 grand is a good deal... the turbo and manifold are worth that alone, looks like its missing some IC hoses, water lines ect... but wont be too hard to source.This kind of conversion is easy and affordable for the DIYer, but if you have to pay a shop it will add up to around what it may cost to trade in on an xr6t.Do the math and make your decision Link to comment https://www.fordxr6turbo.com/forum/topic/43711-turboing-my-bf-xr6-na/#findComment-647499 Share on other sites More sharing options...
XR6 Turbo Developments Member 100 Member For: 17y 3m 2d Gender: Male Location: Dandenong Posted 19/03/08 01:06 AM Share Posted 19/03/08 01:06 AM That’s a cheap price but keep in mind you will also need some type of boost controller. If you decide to use the factory boost controller you will need to also change your ECU and wiring harness which will have the plugs for the boost controller.On top of what you have I can see the following required to do it correctly.BA\BF plenumBF XR6 Turbo ECUXR6T injectors.XR6T boost controllerXR6T engine wiring loomWater and oil pipesIntercooler pipes hot side and cold side pipesTurbo Exhaust systemBoost sensor (under battery pipe)There are probably more things but these are just what I noticed right away. Link to comment https://www.fordxr6turbo.com/forum/topic/43711-turboing-my-bf-xr6-na/#findComment-647558 Share on other sites More sharing options...
Tree Monkey Member 685 Member For: 17y 5m 10d Gender: Male Location: brisvagas / Manly Posted 19/03/08 01:03 PM Share Posted 19/03/08 01:03 PM (edited) XR6 Turbo Developments said: That’s a cheap price but keep in mind you will also need some type of boost controller. If you decide to use the factory boost controller you will need to also change your ECU and wiring harness which will have the plugs for the boost controller.On top of what you have I can see the following required to do it correctly.BA\BF plenumBF XR6 Turbo ECUXR6T injectors.XR6T boost controllerXR6T engine wiring loomWater and oil pipesIntercooler pipes hot side and cold side pipesTurbo Exhaust systemBoost sensor (under battery pipe)There are probably more things but these are just what I noticed right away.I have just done a conversion from na xr6 to xr6t. I picked up a motor, no harness or computer or pipework for $1750. The harness IS THE SAME except for the plug on the map/air temp sensor on the intake manifold. The only other harness you need goes from next to the air filter box to the 3rd plug on the pcm BUT if you run a aftermarket boost controller you wont need a differant pcm, patch harness, boost controll solinoid. I did get a factory intercooler setup but went with a RAPID hot and cold side set up and bigger intercooler. Injectors, you can pick up a set of semins from the states for $300aud or less delivered(pm me for info). Intake manifold, if you use yours just remove or fix open the bbm butterflys. You should be able to pick up a lo km motor of ebay at around $2000-$2500. GET A FLASH TUNER AND THAT WILL REPROGRAM YOUR PCM TO RUN A TURBO SET UP. The othe differance in the motors are pistons and exhaust valves, (lower compression and better valves). The diff is the only othe week link but call mall wood and he can do a 4 pin setup and better gears than the turbo boys have or find a wrecker with the v8 or turbo one. I did mine for under $4000 and will put out 350rwkw. I do know a guy who has a full setup from a o7 bf f6 ute with under 10,000kms for $5000. Edited 19/03/08 01:05 PM by Tree Monkey Link to comment https://www.fordxr6turbo.com/forum/topic/43711-turboing-my-bf-xr6-na/#findComment-647890 Share on other sites More sharing options...
blueboost Member 1,204 Member For: 20y 11m 22d Gender: Male Location: Mackay NorthQueensland Posted 19/03/08 08:32 PM Share Posted 19/03/08 08:32 PM EGOBFXR6 said: Hey guys,Saw on a classified site a fella who was selling a turbo assembly. He says its for a BA, so I'm assuming it will fit my BF?There is a pic attached at the bottom of the post - is this all I need? How much will it cost to have it fitted and such?He said, " I have for sale a GENUINE XR6 Turbo Kit. The Turbo is BRAND NEW (cost around $4100 to buy from Ford alone) The intercooler, exhaust manafold and top manafold were off a new XR6 Turbo that upgraded to aftermarket parts.(all parts are in perfect working order, the intercooler has a couple of small scratches but you can't see it in the car anyway) As far as I know, besides the air pipes and a retune of the factory computer, this is everything you need for the conversion"He is asking $1999 for just whats shown - good deal? How much will I be looking at in total?Cheers,Danyeh as others have said, there is a few pipes missing, although if you ask the guy, he might have them, because if he changed everything he should not have needed them. sounds a good deal.you can use your ecu. and for boost you can run a vacum hose straight from the actuator to the manifold, that will controll it old style, and it will give you 4-6 psi,you can lift the boost with a blead valve further if you want, but it will make better power then a standed tubo car at this boost) I would get a standed turbo exhaust(which he might have) you will need to get a turbo fuel regulator, and turbo injectors (again he should have, or you can pick them up for about a $100.00 dollars for the set, a turbo map sencer (2bar) this will need a tune but will be very nice for the money spent, and will kill the super charger setup. David Link to comment https://www.fordxr6turbo.com/forum/topic/43711-turboing-my-bf-xr6-na/#findComment-647932 Share on other sites More sharing options...
private9 Member 49 Member For: 17y 4m 21d Gender: Male Posted 22/03/08 11:25 AM Share Posted 22/03/08 11:25 AM Looks like a good deal IMO.There's still a few things needed as mentioned above, but it's still a good price.If you were to pay someone purely for fitting, you'd be looking at an absolute minimum of $1000 and then you'll need to consider a tune as well. Link to comment https://www.fordxr6turbo.com/forum/topic/43711-turboing-my-bf-xr6-na/#findComment-649163 Share on other sites More sharing options...
chooch Member 256 Member For: 21y 3m 15d Location: Adelaide Posted 22/03/08 11:31 AM Share Posted 22/03/08 11:31 AM dude, so what if it's cheap! just but an BF T. One thing I have learned is just buy a fast car from the begining. You might end up spending the same amount in the long run.....but with much less hassle. Resale value might be an issue also. Link to comment https://www.fordxr6turbo.com/forum/topic/43711-turboing-my-bf-xr6-na/#findComment-649167 Share on other sites More sharing options...
104ord Member 391 Member For: 17y 2m 2d Gender: Male Location: north brisbane Posted 25/03/08 09:32 AM Share Posted 25/03/08 09:32 AM jump on that deal before I do hahaha Link to comment https://www.fordxr6turbo.com/forum/topic/43711-turboing-my-bf-xr6-na/#findComment-650301 Share on other sites More sharing options...
